It is currently Sun Jun 24, 2018 9:26 am
PostPosted: Wed Apr 19, 2017 9:36 am
NEW FEATURES:
      Quote:
      Tip.If you use 2 GPUs for tracking, you need to turn it off by unchecking second GPU via ''Help > Manage GPU Usage'' menu.
      Quote:
      Note. Built-in rig for ''Blender'' has been removed, because there is no need in change of axes orientation for modern versions of Blender.
BUG FIXES:
UNDER THE HOOD:
See release notes
