It is currently Sat Sep 26, 2020 5:12 am
Post a new topicPost a reply Page 1 of 2   [ 15 posts ]
PostPosted: Sun Jun 27, 2010 7:55 am
Hello everyone,
I just discovered this site yesterday thanks to this month's "3D World" magazine and, I have to say, I'm VERY excited about the desktop motion capture system. I'm currently training to be a Massive TD (massivesoftware.com) and one of the hardest things about it is getting hold of decent motion capture data (I know that there's tons of it on the web, but not much of that is suitable for use in Massive) so the thought that I could generate my own mocap is very exciting indeed.
Anyway, I thought a good first step would be to download one of the BVH files from the Gallery page and see if it would work in Massive. Here's a video of the result (There are 200 agents, in case you were wondering):
http://vimeo.com/12891651
It seems to work OK, but it looks as though the feet are pointing backwards. I'll have to do some investigating to see what's happening...
Cheers.
PostPosted: Wed Jun 30, 2010 10:20 pm
Yes, I see what you mean. Perhaps a tweak on one of the values will turn them in the correct direction. Looks impressive for a first run though. Never used Massive; is that a crowd simulator?
PostPosted: Thu Jul 01, 2010 1:06 am
I haven't had chance to investigate yet, but you're right. It probably just needs a few tweaks to the bone parameters. I tried it with the other BVH file of the guy dancing and the legs do move the way they should, so it should be an easy fix.
To answer your question - Yes, Massive is a crowd simulator. It's what Weta Digital used to create those huge battle scenes in the Lord of the Rings movies. Here's a link to the "What is Massive?" page on the Massive website:
http://www.massivesoftware.com/whatismassive
Cheers.
PostPosted: Thu Jul 01, 2010 5:20 pm
Thanks for posting this interesting video.
You are using very old animation sample. We just updated our Gallery page with new animation samples (in various formats):
http://www.ipisoft.com/gallery.php
You can try the new animation samples, maybe Massive will like them more.
If you have an example of a skeleton that Massive can import correctly you can use our motion transfer to re-target animations to that skeleton. See the "Export" tab in iPi Studio.
PostPosted: Fri Jul 02, 2010 11:21 am
Thank you Michael.
I have tried the new BVH file and (almost) everything looks good now. Here is the result:
http://www.vimeo.com/13038889
The only problem I have now is with the zero pose of the skeleton. When I import it into Massive it is not in the usual T-pose. Instead, it looks like this:
Then, during the first 8 frames of the simulation, it corrects itself:
As you can imagine, it would be almost impossible to skin any geometry to it in this pose. There may be a way to fix this inside Massive though. I will look into it.
PostPosted: Fri Jul 02, 2010 12:27 pm
Here's a trick you can try: open the mocap file in iPi DMC. There are probably frames of the rig in the original T-Pose before the frame where you set your own T-Pose and started tracking. Select the Actor and select Copy Pose from the Edit menu, and paste that pose in the first frame of the range you're exporting. The T-Pose will not necessarily be where the animation starts, but it should be at the origin of the scene (unless, I guess, you used Recenter Coordinate System on the moved Actor, but you can set this back of course by selected the unmoved/posed actor and Recenter.) This should be suitable for 'skinning' or binding your character in another 3D app.
Having the original T-Pose at the original at the beginning of a motion clip can also help with other things like being able to use dynamics (cloth, hair, etc.,) properly. This may or may not be helpful with some 'motion-mixing' apps though.
PostPosted: Sat Jul 03, 2010 4:07 pm
Apparently, you used the walk.bvh file from our Gallery page. Try alternative formats - walk_biped.bvh or walk_endorphin.bvh, maybe Massive will like them.
Better yet, import your own character into iPi Studio and your animation will be retargeted to your rig. (Use "Import target character" on "Export" tab. ) In this case, you won't have to do any rigging or skin binding at all, because exported animation will be fully compatible with your skeleton and your skin weights.
Strictly speaking, this is a problem with Massive. All animation samples from our Gallery page have first frame of animation set to T-pose. This is easy to see if you open our BVH samples in any BVH viewer. For example, you can use BVHacker ( http://www.bvhacker.com/ ). (By the way, iPiStudio also functions as a viewer for any BVH files - use File->Import menu item).
In fact, iPi Studio always inserts meaningful "default pose" as the first frame when exporting animation. "Default pose" usually means T-pose, but for some formats it can be different from T-pose (for example, Valve Biped characters have different default pose due to Valve requirements). For custom characters, "default pose" is set to the pose that was in the first frame of the imported character file.
PostPosted: Sun Jul 04, 2010 1:05 am
That's good to know! Thanks for the info!
PostPosted: Sun Jul 04, 2010 6:44 am
Thank you for all the advice guys. I'll give it a try and see what I can come up with :-)
PostPosted: Wed Jul 07, 2010 3:08 am
Hello again.
I just wanted to let you know that I was able to fix the skeleton inside Massive:
So now everything is good to go :-)
Cheers.
