It is currently Wed Jun 03, 2020 1:06 pm
PostPosted: Tue Aug 11, 2015 2:39 pm
I tried to redo the tracking(3 times) change the computer, change export method etc... Can't export this one.
But other anims i did in the same session are fine, only this one is crashing.
A unexpected error ocurred in the application. Now it will be terminated.
iPi Mocap Studio version 3.2.3.190
ENVIRONMENT
OS: Microsoft Windows NT 6.1.7601 Service Pack 1 (64 bits)
.NET: 4.0.30319.34209
CPU count: 8
GPU Information:
AMD Radeon R9 200 Series (VendorID=1002h, DeviceID=6810h, SubsystemID=E271174Bh, Revision=0h)
Memory: 2,0 GB dedicated video + 0 B dedicated system + 3,8 GB shared system
Outputs: (1366x768@60 R8G8B8A8_UNorm)
PROCESS
GC: Workstation (Interactive)
Running in 64 bits
EXCEPTION
System.IndexOutOfRangeException: O índice estava fora dos limites da matriz.
Server stack trace:
em #=qNFPIaMBTVhYMRtVDkeu_dDsKAza7sLNcOLJn0rFn1NV8QYRVt9m6p8ob$vMMJv_w.#=qypVvd0EPRx9XUPDH6xhdovIIxIXSnJVugE1ZvHiwt8E=(#=q0gaYQqR9gXU65rM3ypeucnm2GzV0puYmY2x77MrjC4g= #=qMfBHfMe_5vADVEphjJQcXw==)
em #=qNFPIaMBTVhYMRtVDkeu_dDsKAza7sLNcOLJn0rFn1NV8QYRVt9m6p8ob$vMMJv_w.#=qObSoUeQfbG83cC7AsLOgIQTQm_dnYmj7RR0xxu6iOCo=.#=q_QoFiQFilo2EPvJNN4yBhrUtENTOi7GSycY1Pc0lDxU=()
em System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs)
em System.Runtime.Remoting.Messaging.StackBuilderSink.AsyncProcessMessage(IMessage msg, IMessageSink replySink)
Exception rethrown at [0]:
em System.Runtime.Remoting.Proxies.RealProxy.EndInvokeHelper(Message reqMsg, Boolean bProxyCase)
em System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(Object NotUsed, MessageData& msgData)
em System.Action.EndInvoke(IAsyncResult result) em #=qEec_klz4QutSgUxPXatJtG5amVAL$EpGvJYHOR$hP$0=.#=qQl9XH5ij9vI8vbzZXZTcBzDwe5j3eT0A29Z5h_JgASo=(MethodBase #=qn4ESuf8TOyAGH3jIG8lIMg==, Boolean #=qmucs8CDaeA8JDsyjkJEFiQ==)
em #=qEec_klz4QutSgUxPXatJtG5amVAL$EpGvJYHOR$hP$0=.#=q01iAPxZ0hRQdT1CfhOKdrHTxZLZtZO9M_BL9dbl4quI=()
em #=qEec_klz4QutSgUxPXatJtG5amVAL$EpGvJYHOR$hP$0=.#=qKqNrFinrxrIlrAyIPdlHhw==() em #=qEec_klz4QutSgUxPXatJtG5amVAL$EpGvJYHOR$hP$0=.#=q2nwjB6VtB4xFTRvo4kNa0xtLvCmHnKTINsSQIqquAuI=(#=qPscTXIlMGZR8lav0T7oULimqvwA6oZQijuU$3HwMiSg= #=qn4ESuf8TOyAGH3jIG8lIMg==)
em #=qEec_klz4QutSgUxPXatJtG5amVAL$EpGvJYHOR$hP$0=.#=qKqNrFinrxrIlrAyIPdlHhw==() em #=qEec_klz4QutSgUxPXatJtG5amVAL$EpGvJYHOR$hP$0=.#=q75drtpeGMjtFxlHWGq70yKmrz4HYwWElzw8x3Rec57s=(Object #=qn4ESuf8TOyAGH3jIG8lIMg==)
em #=qEec_klz4QutSgUxPXatJtG5amVAL$EpGvJYHOR$hP$0=.#=qG_NVqdCGXNMu_cMpiZBZfdhJdTdlZEcfOJIUXh3YUfM=()
em #=qEec_klz4QutSgUxPXatJtG5amVAL$EpGvJYHOR$hP$0=.#=qH2dF_0zntXZGbn8RrKDTSrZK0HPvhLUpsUpwZe_V$ow=()
em #=qEec_klz4QutSgUxPXatJtG5amVAL$EpGvJYHOR$hP$0=.#=qHnFqNJlKWqxi7JqYZlSrVP$CUoO$llwnDWwAxf7QibI=() em #=qEec_klz4QutSgUxPXatJtG5amVAL$EpGvJYHOR$hP$0=.#=q75drtpeGMjtFxlHWGq70yKmrz4HYwWElzw8x3Rec57s=(Object #=qn4ESuf8TOyAGH3jIG8lIMg==)
em #=qEec_klz4QutSgUxPXatJtG5amVAL$EpGvJYHOR$hP$0=.#=q8Dfokt3Sj_CACAl0f8zDsx6o04l5GPqv7r_bLYmSO7M=(Object[] #=qn4ESuf8TOyAGH3jIG8lIMg==, Type[] #=qmucs8CDaeA8JDsyjkJEFiQ==, Type[] #=qwkHzNhEsydyL6nNdEX2EyA==, Object[] #=qOMpfYfxZCStyBtB1X5Q7Pg==)
em #=qEec_klz4QutSgUxPXatJtG5amVAL$EpGvJYHOR$hP$0=.#=q9J8dBRSa1V_IlfoSSm1wBtKCtfOFK_ByovTSAMacpGk=(Stream #=qn4ESuf8TOyAGH3jIG8lIMg==, String #=qmucs8CDaeA8JDsyjkJEFiQ==, Object[] #=qwkHzNhEsydyL6nNdEX2EyA==)
em -.dje_q7DAUESASUVBLCTW4FUJLVUKCUN3R5YPK43FFMPA9J9NW746Y24EPAVJDELZ9GBPELGEYZ25T5NYVX_ejd.#=qoPuHThOXf_fFZFcz3_IMXJ6lE3Sl0lwK7$brWmdSu7Y=(IAsyncResult #=q$8NfhoNZaTmX67WHsD46cA==)
em System.Runtime.Remoting.Messaging.AsyncResult.SyncProcessMessage(IMessage msg)
em System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
em System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
em System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
em System.Threading.ThreadPoolWorkQueue.Dispatch()
Charles Marcolim - Animation Lead - CoffeeAddict Studio
PostPosted: Fri Aug 14, 2015 10:13 am
Please send the problematic project file to our tech support email. I think we won't need the video file itself as long as the issue appears at the export stage.
