ipisoft.com
http://forum.ipisoft.com/
OBJ sequence export
http://forum.ipisoft.com/viewtopic.php?f=13&t=9758
Page 1 of 1
Author:  Tim [ Sun Apr 23, 2017 2:57 am ]
Post subject:  OBJ sequence export
Hi!
would it be possible to export the point cloud data as an OBJ sequence instead of baking each frame into one OBJ file?
Cheers,
Tim
Author:  vmaslov [ Sun Apr 23, 2017 12:08 pm ]
Post subject:  Re: OBJ sequence export
Currently, when you select All frames in ROI for export, all frames are put in a single OBJ file as separate objects named frame_xxx. Do you actually need a sequence of OBJ files?
Author:  Tim [ Mon Apr 24, 2017 2:00 am ]
thanks for getting back.
Yes, actually a sequence would be great - so each frame of ROI as a seperate OBJ. That's what most Visualisation Plugins can read.
As a workaround I export now current frames separately which get's a bit annoying for moren than 30 frames :)
Best
Author:  vmaslov [ Mon Apr 24, 2017 2:42 am ]
Please name a few plugins you use so we can test export into a sequence.
Author:  Tim [ Tue Apr 25, 2017 1:34 am ]
Trapcode Form, Plexus or Stardust are great After Effects Plugins which translate the OBJ-pointcloud into particles.
Author:  Greenlaw [ Tue Apr 25, 2017 2:24 am ]
Oh, I never thought to use those tools that way. Thanks for the info. Learn something new every day. :)
http://www.phpbb.com/
