To be honest, I have never gotten good tracking with natural colored hands, always looses tracking too easy, try wearing light material, solid color gloves.
Feet should be covered in a solid color footwear also, one color shoe and sole works better, and non-shiny.
Last images for red shirt, natural arms, dark pants should be fine, solid dark colors for hands and feet work and track better.
Agree that scene light in iPi Studio should match the brightest direction of world light, move the light with the blue box filled with numbers above the place light button, left click hold in this box and drag cursor through this box to change the scene light positioning, scroll view port out to see this light better.
Personally I think it is the hands and feet not covered properly and hair should be off the back of the neck to expose rear of neck, use hair tie, or rubber band to at least bunch hair, or tuck under knit cap used in prior screenshots and tuck hair inside, loose fly away hair will make head tracking poor, since no Move controllers are being used.
All of this should help tracking, as lighting isn't that bad you used on the outdoor scene anyway, works best when 1 side of performer is lit more than he other, but rear side shouldn't be so dark, small wattage fill light at rear will help this.
That kick action is a very basic action for iPi to track fine, so the issue is in the hands and feet covering, in my opinion, even in lower light conditions with grainy footage it should track Ok, as long as the lighting is more equally distributed around the performer to not have very dark areas on the clothing from not enough light on the shirt, as dark, or black color will always look dark of course, so use of a brighter color T shirt would be suggested in lower light conditions.
Try these suggestions and see if your tracking quality doesn't improve greatly.
