http://forum.ipisoft.com/
angles and translation specific values
http://forum.ipisoft.com/viewtopic.php?f=2&t=10069
Author:  NicoDownBeat [ Tue Jan 08, 2019 3:12 am ]
Post subject:  angles and translation specific values
Hello everyone.
Is there a way for entering bones' angles and translation specific values?
For example if I want to rotate Lforearm like this: Rx 45.0000 Ry 25.0000 Rz 60.0000, how can I?
Thank you.
Author:  vmaslov [ Wed Jan 09, 2019 12:27 pm ]
Post subject:  Re: angles and translation specific values
No, there is no such capability. Please tell why do you need that.
Author:  NicoDownBeat [ Thu Jan 10, 2019 3:08 am ]
Suppose to know Lleg's exact position's and rotations' value, you can set it on in ipi mocap studio. At this point press "refit pose" button. Lleg's position and rotations will change. I'm interested in knowing the new values and compare them with the exact values above.
Anyway in generally simple numbers are easier to memorize when you work and you want to compare them from different frames for example.
Author:  vmaslov [ Thu Jan 10, 2019 5:56 am ]
Still not quite getting your intention.
Do "exact" values come from some other system or represent a kind of "ideal" pose? In any case before comparison you need to ensure that both sets of values use the same coordinate system - origin, axis orientation, order of Euler angles.
Why do you need to set known values in editor before Refit if you're only interested in Refit results?
