It is currently Sun Jun 07, 2020 1:41 am
PostPosted: Fri Jan 08, 2010 10:02 am
Hi all,
I am currently performing various tests to measure the quality of captured motions, and I have thus far encountered two kinds of motion that I am unable to capture well, namely head orientation movements (e.g., yes-no motions with otherwise static body) and wrist orientation changes (e.g., circle motion of the wrists with otherwise static body).
Although I have been moderately successful with wrist motions, I must confess that I´ve had no luck with head motions.
This post is to identify if I´m encountering a limitation of the system, or if my issues are more related to my current camera/actor setup. So, as a first iteration, I´d like to know if someone has successfully captured such kind of movements.
To give you a general idea of my current setup, I use three cameras (located roughly North, NorthEast, NorthWest, with the actor facing North), good illumination, a light background, and the actor is light-skinned, dark-haired and wears blue jeans, black short-sleeved T-shirt over green long-sleeved T-shirt.
TIA,
Adolfo Rodríguez Tsouroukdissian, Ph. D.
Robotics engineer
PAL ROBOTICS S.L
http://www.pal-robotics.com
Tel. +34.93.414.53.47
Fax.+34.93.209.11.09
PostPosted: Fri Jan 08, 2010 12:38 pm
The software doesn't currently track the head or hands. I believe they are planning to add these features in a future release.
PostPosted: Fri Jan 08, 2010 2:58 pm
Head tracking is planned. Hand tracking is something for later versions of the software.
You say you HAVE been moderately successful with wrist motion? How are you doing it?
PostPosted: Sat Jan 09, 2010 1:23 pm
I know the Standford University team took the video and translated it into a silhouette video on their markerless mocap. Perhaps that might be the ticket for achieving the best mocap translation.
Performance Capture from Sparse Multi-view Video
Good luck...
PostPosted: Wed Jan 13, 2010 5:27 am
Thank you all for your answers concerning current capabilities and future plans.
Wrist motions only, without arm motion: no success. Tried once or twice, then dropped the efforts.
In a motion where the arms were moving and the hands experienced small motions, I had the said moderate success. However, what I did was highly manual. I would manually set the hand pose after an initial tracking, then propagate forward, and whenever the hand pose diverged substantially from the video, I would stop the propagation, readjust manually, and resume. Lather, rinse, repeat ;)
Best,
Adolfo
