It is currently Sun Jan 26, 2020 5:26 pm
 Post subject: Camera angles ?
PostPosted: Sat Apr 11, 2009 11:35 am
I was wondering what are the best angles one could use for the camera rig ?
I was watching the video you guys have of the dancing man they seem to be separated by about 30 degrees or so, I was setting up my rig so 1 camera was at the front of the actor and the other at 90 degrees from the first camera something like this:
( it is looked from the Z plane ) birdseye view:
Code:
         0
        /|\   ================== CAM
         cam
however it seems you guys use inclination:
Code:
                       CAM
         0      /
                      \cam
so what's the recommended setup for this ?
 Post subject: Re: Camera angles ?
PostPosted: Sat Apr 11, 2009 11:38 pm
In general, you need 60-90 degrees between cameras.
I would recommend to start with 3-camera setup with 60-70 degrees between cameras. Make sure that your 3 cameras are not set up in one line. Set them in semi-circle. It helps setting cameras at different height (like one camera higher then other 2).
2-camera setup is only useful for simple motions. We used it in our 8-month-old demo just as experiment. I recommend 3- or 4-camera setups for complex motions.
PostPosted: Sun Apr 12, 2009 9:09 am
So for a 3 camera setup you don't recommend setting up all the way around the actor? 120 degs apart. A semi circle is good enough?
Donny
PostPosted: Sun Apr 12, 2009 3:06 pm
Semi-circle should be good enough.
An illustration is embedded in iPi Studio. Open a 3-camera video and look at default camera positions.
Users browsing this forum: No registered users and 5 guests
