It is currently Sun Jul 12, 2020 12:21 am
PostPosted: Sun Sep 12, 2010 8:29 pm
I've successfully captured motions of myself and several friends, and I'm very happy with how the software is working. I've imported the .bvh files into Blender, but I'm running into difficulties applying a mesh to the armature.
The problem is that the hierarchy portion of ipisoft bvh files define a "pile of bones" that then get unfolded within the motion portion of the files. What Blender expects is that the bones as defined in the hierarchy fully constitute a T Pose; which is to say that the first "T-Pose" frame of the motion section have all rotations set to zero.
I tried recasting the hierarchy section in a more Blender-friendly form. The file imports into Blender just fine, and it looks identical to the original ipisoft file, but I can't get ipisoft to import my restructured file as a target character ("Import string was not in a correct format.")
Any suggestions?
Here is the file I constructed:
HIERARCHY
ROOT Hip
OFFSET 0.000000 0.000000 0.000000
CHANNELS 6 Xposition Yposition Zposition Xrotation Yrotation Zrotation
JOINT LowerSpine
OFFSET 0.000 7.342 -4.513
CHANNELS 3 Xrotation Yrotation Zrotation
JOINT MiddleSpine
OFFSET 0.000 9.552 0.000
JOINT Chest
OFFSET 0.000 13.460 0.000
JOINT Neck
OFFSET 0.000 22.577 0.527
JOINT Head
OFFSET 0.000 7.815 0.000
End Site
OFFSET 0.000 17.367 0.000
JOINT RClavicle
OFFSET -2.779 20.840 0.000
JOINT RShoulder
OFFSET -13.720 -3.473 0.869
JOINT RForearm
OFFSET -27.472 -1.996 -1.202
JOINT RHand
OFFSET -23.202 0.696 0.857
End Site
OFFSET -13.904 -0.452 0.513
JOINT LClavicle
OFFSET 2.779 20.840 0.000
JOINT LShoulder
OFFSET 13.720 -3.473 0.869
JOINT LForearm
OFFSET 27.472 -1.996 -1.202
JOINT LHand
OFFSET 23.202 0.696 0.857
End Site
OFFSET 13.904 -0.452 0.513
JOINT RThigh
OFFSET -7.815 0.394 0.000
JOINT RShin
OFFSET -0.434 -37.947 0.000
JOINT RFoot
OFFSET 0.000 -39.349 -0.356
JOINT RToe
OFFSET 0.000 -3.461 10.729
End Site
OFFSET 0.000 0.000 5.959
JOINT LThigh
OFFSET 7.815 0.394 0.000
JOINT LShin
OFFSET 0.434 -37.947 0.000
JOINT LFoot
JOINT LToe
End Site
MOTION
Frames: 1
Frame Time: 0.0666660000
0.000000 81.941090 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
PostPosted: Mon Sep 20, 2010 1:07 pm
Please remove the empty string between "Frames:" and "Frame Time:" in your BVH file. It will fix the problem.
PostPosted: Wed Sep 22, 2010 7:26 pm
It's always the simple things, isn't it? Thanks!!!
