http://forum.ipisoft.com/
Adjusting the skeleton
http://forum.ipisoft.com/viewtopic.php?f=2&t=70
Author:  SunG [ Wed Apr 29, 2009 7:45 pm ]
Post subject:  Adjusting the skeleton
Hi all how do you manually adjust the skeleton(scale it) ?
Author:  Michael Nikonov [ Fri May 01, 2009 3:17 pm ]
Post subject:  Re: Adjusting the skeleton
You can use "Height" control on "Actor" tab to adjust actor height/scale.
Also, you should make sure your scene has correct scale. After calibration, you should use "Scale" control on "Calibration" tab to set correct scale for the scene. You should make sure that camera height and distance between cameras correspond to real-work distances after calibration. This is not very intuitive but is extremely important.
