It is currently Sat May 30, 2020 8:58 am
 Post subject: Laptop
PostPosted: Fri Oct 30, 2009 11:08 pm
Excellent idea/software btw
Sorry if I'm posting this in the wrong section.
What are the recommended specs for a laptop? Processor, Memory, usb ports. I see you recommend a camera, please recommend a couple laptops or specs.
I currently have an Abus 2gig ram T5500 duo, running the built in webcam and a cheap external webcam (just for testing). The cache indicator is constantly full but not red at 320x240. In 640x480 the indicator is red and only records 2secs before stopping.
So I realise I'll have issues if I try running 3 logitechs at 640x480.
I was reading on the forum about usb problems on a desktop using the same port causes usb bandwidth problems. Is this common with laptops? Hopefully your answers will clarify this for more.
Once again, excellent software, looks like a definite purchase for me within the next 4 weeks. How long does your current price offer last for?
 Post subject: Re: Laptop
PostPosted: Wed Nov 11, 2009 1:00 pm
Most dual-core laptops are not fast enough to capture multi-camera video at 640x480.
In future versions of iPi Recorder, it will be possible to use camera built-in MJPEG compression if camera supports it. For example, many UVC-certified (USB Video Class) cameras support MJPEG compression. Camera-side compression saves USB bandwidth and CPU time and should allow recording at high resolutions on laptops.
For now, I recommend that you capture at 320x240.
