It is currently Thu May 23, 2019 2:31 pm
PostPosted: Tue Oct 24, 2017 9:28 pm
Dear experts,
As you know, iPi software has built-in auto update functionality. Auto update feature is configured so that checks for update are made once per day. Could you please let me know how to disable this auto update function? Becasue in my use case, iPi software is working with Automation Adds-on, so an update window will block my work flow. I have to manully close the update window then the work flow can go on. Thank you so much for your kind help.
BTW, I can not use the method of turning off the network connection.
Best regards,
Shawn
PostPosted: Wed Oct 25, 2017 3:03 am
The update window is actually brought to you only once on app exit after discovering a new update. Maybe this window should not be shown while there is an active connection with an Automation client. We'll think about this.
There is no way to disable the autoupdate feature in the program. However, you can fool it to prevent checks by making some edits in Windows registry. Here are the steps for Mocap Studio
  • Delete value HKEY_CURRENT_USER\Software\iPi Soft\iPi Mocap Studio 3\Update\Available Version
  • Set value HKEY_CURRENT_USER\Software\iPi Soft\iPi Mocap Studio 3\Update\Last Server Check to the decimal 3155378975999999999.
The same steps go for Recorder, just replace iPi Mocap Studio 3 with iPi Recorder 3 in value paths.
