ipisoft.com http://forum.ipisoft.com/ |
Tutorial: mocap data from iPi Mocap Studio to Cinema 4D http://forum.ipisoft.com/viewtopic.php?f=3&t=8935 |
Page 1 of 1 |
Author: | heilei [ Mon Jan 13, 2014 12:17 pm ] |
Post subject: | Tutorial: mocap data from iPi Mocap Studio to Cinema 4D |
How to import motion capture data from iPi Mocap Studio (iPiMS) to Cinema 4D (C4D) At first, please note that the workflow I describe below does not apply to all possible scenarios and pipelines. This is only a very basic example, with the following limitations:
1. Create your character mesh and its rigging in C4D:
2. Export your character from C4D to an FBX file (File > Export > FBX). In the export dialog, my FBX settings were as follows:
Attachment: 2-C4D export settings.png [ 56.43 KiB | Viewed 30670 times ] 3. Import the FBX file into your iPiMS project:
4. Under Motion Transfer Profile, map your character's joints to iPiMS joints from the drop-down menus. Choose "(Unused)" for joints that your character does not have (like clavicles etc. in my example). If you used an identical naming scheme in C4D, this step is boring but easy, and you only have to do it once: you can (and should) save you mapping info into an XML file with the "Save..." button in iPiMS. If you ever need to change a joint name in C4D or make any other minor mapping adjustments, you can manually edit this XML file with a text editor (which is a lot faster than doing the drop-down menu gymnastics again). 5. Play your video in iPiMS a few times to make sure all joints are mapped correctly and your C4D character is moving along with your mocap actor. If not, something is not right, either in your rig or the joint mappings (or, more likely, in the author of this tutorial). 6. Export your mocap data from iPiMS as an FBX file:
7. Import (or merge) the new FBX file into C4D (File > Open... or File > Merge...). My FBX import settings were as follows:
Attachment: 4-C4D import settings 1.png [ 70.49 KiB | Viewed 30670 times ] 8. You should now have your original character in C4D with mocap animation... Go ahead and press play! I'd appreciate any comments from all you C4D and/or iPiMS gurus out there; this is only a straightforward description of one workflow that seems to work, with all the limitations I listed in the beginning. |
Author: | heilei [ Fri Jan 17, 2014 5:12 am ] |
Post subject: | Re: Tutorial: mocap data from iPi Mocap Studio to Cinema 4D |
heilei wrote: My character hasn't been painted; i.e. the C4D project doesn't yet have any fancy materials. There's just the default white texture, which is applied to the whole character. I have no idea how well material and texture mappings survive the FBX roundtrip I describe below. Addendum: after a few more tests, it seems that a FBX roundtrip from C4D to iPiMS and back does retain textures, materials and polygon selection tags as well. |
Author: | xxlwd@t-online.de [ Sat Apr 12, 2014 2:05 pm ] |
I test your addendum: The fbx rountrip from C4D to ipisoft and back: From c4d into ipi: skin ok, but loosing all textures From ipi then to C4D: everything lost, skin and textures, skeleton only after import. |
Author: | heilei [ Mon Apr 14, 2014 12:20 am ] |
I wonder if this might have something to do with absolute vs. relative texture paths? If your textures in C4D use relative paths, they probably break at some point during the FBX import/export process. I'm not at my C4D at the moment, and I really can't remember which method I used. I assume absolute texture paths should work. |
Author: | xxlwd@t-online.de [ Mon Apr 14, 2014 9:01 am ] |
heilei wrote: I wonder if this might have something to do with absolute vs. relative texture paths? If your textures in C4D use relative paths, they probably break at some point during the FBX import/export process. I'm not at my C4D at the moment, and I really can't remember which method I used. I assume absolute texture paths should work. Reply: In my example, i my example i used in the c4d file only materials colored etc..no real texture…to the related character model, weighted and skin. |
Author: | heilei [ Mon Apr 14, 2014 10:44 pm ] |
Unfortunately I have no experience in C4D's weighting and skinning system. As I mentioned in my tutorial, it was a very basic example (no weights, no IK, no character tools etc.). It might be that adding weights and/or skin to the character somehow breaks the FBX import/export chain. I have no idea if the FBX format even supports weights or skins. The format is very poorly documented (blame Autodesk). You might be able to test this by first exporting your scene as FBX and then importing it back in. Is the imported character still weighted and skinned? |
Author: | madmonkfish [ Tue Apr 15, 2014 1:58 pm ] |
heilei wrote: Unfortunately I have no experience in C4D's weighting and skinning system. As I mentioned in my tutorial, it was a very basic example (no weights, no IK, no character tools etc.). It might be that adding weights and/or skin to the character somehow breaks the FBX import/export chain. I have no idea if the FBX format even supports weights or skins. The format is very poorly documented (blame Autodesk). You might be able to test this by first exporting your scene as FBX and then importing it back in. Is the imported character still weighted and skinned? I posted the method below in the Import/Export and Motion Transfer/Importing BVH animation thread, so it might be of use to the xxlwd@t-online.de. The FBX format supports weights/bones (classic skinning) and has pretty much from it's beginnings. madmonkfish wrote: I don't use C4D... but, why not export an FBX (so there is the character and the data - already working in a single file) into C4D?
You may already do some of this, but maybe these notes will help: The system I use is this: A. Have a fully rigged/boned/weighted character set up in Lightwave (my program of choice). B. From this, export a T-Pose FBX (so this is the character, all his weights and the bones in a single file) - only 1 frame is needed. C. Now, when you are in IPI, you'll need to do import this FBX - to do this, go to the Export Tab and point it to the FBX you'd like to load in. D. Once that is loaded, you'll need to make a Motion Transfer Profile - if you have set up a standard rig, it'll probably be already done (you'll see if it is, as your imported character will move with your IPI data). E. If not, using the re-target drop downs, select the source IPI bones to re-map to their target bones. F. Now, save on the Motion Transfer file (as you can reload it, if needed and you don't need to repeat the work). G. So, at this point you now have an IPI skeleton rig that is re-targeted to your rig :) H. Last stage, export the take to an FBX, this will save a fully rigged/weighted character in an encapsulated FBX format. I. Then, simply load the FBX back into your CG application (or merge the FBX back with your source scene). Hope that helps. |
Page 1 of 1 | All times are UTC - 8 hours [ DST ] |
Powered by phpBB® Forum Software © phpBB Group http://www.phpbb.com/ |
