It is currently Tue Jul 16, 2019 10:07 pm
 Post subject: Show 3D-Coordinates
PostPosted: Fri Feb 19, 2010 9:48 am
I would like to get the coordinates of all points of the biped in realtime. So capturing the person in realtime and getting the coordinates in realtime.
 Post subject: Re: Show 3D-Coordinates
PostPosted: Fri Feb 26, 2010 12:29 pm
One addition to clarify:
Capture has to be realtime, so as soon as the movement is being done, the camcorder's image is processed and converted into coordinates.
Order:
1. Place yourself in starting position
2. Wait for an acustical sign to be notified that your position has been acquired.
3. Receive the data in real-time, while having the choice to deselect special points of the biped to take the pressure off the cpu.
Data could be recieved in a windows window which can be read by other applications.
How long would something like this take you guys?
PostPosted: Sun Mar 14, 2010 4:33 am
So what can you say, how far is the delevopment in this aspect?
PostPosted: Sat Apr 03, 2010 10:26 am
Modern personal computers are not fast enough for real-time markerless motion capture. If you need a real-time solution, consider using traditional marker-based system.
PostPosted: Sat Apr 03, 2010 12:16 pm
Maybe that is not necessary.
I am thinking of a "project natal" alternative, so movements just have to be translated into "forward", "backward", "fight"...
No precision necessary at all.
What do you think now?
