It is currently Mon Feb 18, 2019 8:31 pm
PostPosted: Wed Sep 05, 2018 3:44 pm
I'm on the evaluation, I have a Kinect 2.
After running Evaluate Background and moving to the Record tab, on pressing Start Recording it always crashes with this,
iPi Recorder 4.0.6.66
OS: Microsoft Windows NT 10.0.17134.0 (64 bits)
.NET: 4.7.2.461808
CPU count: 8
GC: workstation (Interactive)
Running in 64 bits
System.InvalidOperationException: Sequence contains no elements
at System.Linq.Enumerable.Max[TSource](IEnumerable`1 source)
at #=zvcQFbhiNPej6MVas9_TOd5Y=.#=zlEsuflyBo4acUFLb7LtlppQrcXCzym0NhkWNZJE=(Boolean #=z2yMReccDtPhdqeBKkQ==, Int64& #=zkB4cp_oXJR$B, Boolean #=zAil_bycmldHn4x10X3aTXCo=)
at #=zvcQFbhiNPej6MVas9_TOd5Y=.#=zqq6gvYQovUKG(Boolean #=z2yMReccDtPhdqeBKkQ==, Boolean #=zAil_bycmldHn4x10X3aTXCo=)
at iPiRecorder.Recorder.ViewModel.RecordStageViewModel.<StartRecordingAsync>d__122.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at iPiRecorder.Recorder.ViewModel.RecorderViewModel.<ExecuteStartRecording>d__121.MoveNext()
If it makes any difference I initially tried to connect both a Kinect 1 and 2 but was told by IpI Record they were not compatible. I then uninstalled the Kinect 1 drivers and SDK and rebooted and only have the Kinect 2 connected now - it is working fine as seen in Kinect Studio.
Since then I've also completely reinstalled the recorder but always get the same error.
PostPosted: Thu Sep 06, 2018 2:28 am
Thanks for reporting.
The issue has been introduced in the latest release of iPi Recorder 4.0.6. We'll make a fix in a few hours. In the meanwhile you can downgrade to previous release 4.0.5.
Sorry for inconvenience.
PostPosted: Fri Sep 07, 2018 7:12 am
Release v4.0.7.67 fixes this issue.
