It is currently Fri Jul 03, 2020 10:42 am
PostPosted: Thu Jun 25, 2020 12:13 am
i've got 2 plugged in on ipi recorder and both of them just keep going back and forth between these 2 messages https://imgur.com/a/CWmbHQH
PostPosted: Fri Jun 26, 2020 12:18 pm
Does each of Kinects work when connected single?
Are power adapters connected to Kinects?
Have you tried all available USB ports?
How many ports your PC has, is it laptop ot desktop?
PostPosted: Wed Jul 01, 2020 5:39 am
none of the kinects work when single, the power adapters are connected (https://www.consolemate.com.au/Xbox-360 ... senpwr.htm)
it's a desktop with 2 ports infront and 4 in back.
basically what's happening on the pc is it just wants to keep disconnecting, the green light specifically on the kinect is the one that keeps beeping on and off every second.
additionally, somebody suggested to turn off selective USB suspension. after that, the kinect works for about a second longer, and manages to say "Ready" on Ipi recorder for 2 seconds, then goes back to its usual error routine. so my guess is thats 1 issue fixed over a sea of possibly many
PostPosted: Fri Jul 03, 2020 3:20 am
It may a compatibility issue with an USB controller in your PC. For instance, multiple Kinect for XBOX 360 do not work with modern Intel chipsets starting from 8x series.
Which USB controllers have you got? You can find them in Device Manager under USB Controllers node.
Also it may be that recent versions of Windows include some changes that break work of these Kinects.
Do you have an opportunity to check at another PC?
Also, try to install Kinect SDK 1.8 manually and run one of sample applications or tools from it. Does Kinect work with it?
https://www.microsoft.com/en-us/download/details.aspx?id=40278
