http://forum.ipisoft.com/
Kinect v2 desync?
http://forum.ipisoft.com/viewtopic.php?f=5&t=10000
Page 1 of 4
Author:  Zatesz [ Tue Jul 17, 2018 4:25 am ]
Post subject:  Kinect v2 desync?
Hello everyone!
I need a little help with a weird situation. I have two Kinectv2 cameras and two computers.
-Master computer is a PC (cpu i7 4770, Nvidia 1070, Asrock z87 extreme 4 motherboard)
-Slave computer is a Laptop (Asus Q550LF cpu i7 4500U)
Very often when I am recording and try to track, the depth information timeline per kinect camera seems to be out of sync. One camera is either behind or before the other camera in terms of timeline. (I attached a picture "difference.png") As the picture show I have a big difference. What is the problem? Can somebody help me with this? These computers not the newest but they should be powerful enough.
Thanks for the help guys!
Author:  vmaslov [ Wed Jul 18, 2018 12:41 am ]
Post subject:  Re: Kinect v2 desync?
Do you have stable 30 fps at both computers while recording?
Please make screenshots with video info of individual recordings (PC and laptop) from that distributed recording (or another with the same issue). Open each video in Recorder, click Video Info button in toolbar and expand 'track #' items to show the stats.
Author:  Zatesz [ Wed Jul 18, 2018 1:17 am ]
Hello!
I opened all track information under the video info section and i made a screenshot for you. I see the delay from the 3rd second.
File comment: video info
File comment: difference_timeline
Author:  vmaslov [ Wed Jul 18, 2018 1:30 am ]
I see there are some issues with first recording - a few frame gaps and bad frames, although not seeming critical.
Can you please provide similar screenshots for individual recordings before merging into one? That's what I requested actually.
Author:  Zatesz [ Wed Jul 18, 2018 2:25 am ]
ohh okay sorry for the misunderstanding. Here are the individual screenshots:
File comment: master
File comment: slave
Author:  Snapz [ Wed Jul 18, 2018 4:47 am ]
Maybe check that both computers Power setting is on High Performance?
Looks like the Laptop is running better than the Desktop.
Seems that would be the other way around.
Also check that your graphics card is set to prefer High Performance from its settings, although the recorder can run as low as 2G of a CPU and graphics cards aren't primary, but if in the machine, it recognizes them first, it should be set for Studio tracking as well.
Info. here: http://docs.ipisoft.com/Maximizing_GPU_ ... cap_Studio
Author:  Zatesz [ Wed Jul 18, 2018 5:52 am ]
I thought the same, when i am recording i use my computers in high performance mode. Sadly it doesn't help.
Author:  Snapz [ Wed Jul 18, 2018 5:58 am ]
Ok, was worth checking.
Seems if was a software issue, many others would be reporting it in the forum by now.
Is this the first time you tried a Kinect v2 on both machines in Distributed recording mode?
Author:  Zatesz [ Wed Jul 18, 2018 6:10 am ]
I used iPi 3.6 or something similar version under the trial time with 2 kinect but i cannot recognize any issues before. Now when i try to make faster animations i just realized this problem when my body parts fly away.
Author:  Snapz [ Wed Jul 18, 2018 6:19 am ]
Yeah, with Kinects you can't move extremely fast, should be able to move at a slower dance/fighting motion speed though, but the out of sync will cause the problem mostly for the trackers.
May be an issue within the software, I will let iPi continue the research into this, I was just trying some basic troubleshooting that may have helped, but if was working fine in v3, you would think would in v4.
One other thing, do you have only v4 of the Recorder and Studio installed on the Master machine? If you still have v3 installed as a separate program, uninstall it, or if you have already, disregard this.
Hope you get it working as it should soon.
Good Luck!
Page 1 of 4 All times are UTC - 8 hours [ DST ]
