It is currently Mon Feb 24, 2020 11:59 pm
PostPosted: Mon Mar 04, 2019 8:39 pm
After having solved the previous error with .Net, updating my version of Windows, I present this error when starting your program.
Quote:
iPi Mocap Studio version 4.1.1.231 [FREE TRIAL (30 days left)]
ENVIRONMENT
OS: Microsoft Windows NT 10.0.17763.0 (64 bits)
.NET: 4.7.2.461814
CPU count: 2
GPU Information:
Microsoft Basic Render Driver (VendorID=1414h, DeviceID=8Ch, SubsystemID=0h, Revision=0h)
Memory: 0 B dedicated video + 0 B dedicated system + 2.0 GB shared system
Outputs: (1366x768@64 R8G8B8A8_UNorm)
PROCESS
GC: Workstation (Interactive)
Running in 64 bits
EXCEPTION
SharpDX.SharpDXException: HRESULT: [0x8007000E], Module: [General], ApiCode: [E_OUTOFMEMORY/Out of memory], Message: No hay suficientes recursos de memoria disponibles para completar esta operación.
en System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
en System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
en System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes, StackCrawlMark& stackMark)
en System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes)
en System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture)
en #=qL7ZUgfo73X8$rtQTZkjvm8phhoqGC1efRjgw1$j6JIM=.#=zmyYxQcIo8t9411AGHkjjpb8=(MethodBase #=zNme$S1Q=, Object #=zoo4tB6U=, Object[] #=zX2n47KU=)
en #=qL7ZUgfo73X8$rtQTZkjvm8phhoqGC1efRjgw1$j6JIM=.#=z8ZUopxk3lfpez$FIFSc_uxxR3VaQ(MethodBase #=zNme$S1Q=, Object #=zoo4tB6U=, Object[] #=zX2n47KU=, Boolean #=zH4UcPJg=)
en #=qL7ZUgfo73X8$rtQTZkjvm8phhoqGC1efRjgw1$j6JIM=.#=z_C2RQNzbCk5n_FH4E7U_ZtlzMRxCZNeOI561$qw=(#=q5J$J8Nnnw8vpuPj9Y65c$yPyzSGXIoLGMt3X1sze6Zo= #=zNme$S1Q=)
en #=qL7ZUgfo73X8$rtQTZkjvm8phhoqGC1efRjgw1$j6JIM=.#=z4thNeKCrBh6C0peC8Nfyg5o7XUBo1$QrwACXTbI=()
en #=qL7ZUgfo73X8$rtQTZkjvm8phhoqGC1efRjgw1$j6JIM=.#=znVPEJ6rieGagGvc$HYtQhVk=()
--- Fin del seguimiento de la pila de la ubicación anterior donde se produjo la excepción ---
en System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
en #=qL7ZUgfo73X8$rtQTZkjvm8phhoqGC1efRjgw1$j6JIM=.#=z$oe3tRCNqYVhIVaUt16SkTFUlVvN(Exception #=zNme$S1Q=)
en #=qL7ZUgfo73X8$rtQTZkjvm8phhoqGC1efRjgw1$j6JIM=.#=zqnWe4V7Kak$S6_cTonlVjLtsJ1ix(Object #=zNme$S1Q=)
en #=qL7ZUgfo73X8$rtQTZkjvm8phhoqGC1efRjgw1$j6JIM=.#=zitDNo6t0SWdJIjYpT19ohp35IMuC95MxwnOxUE9QcKn_()
en #=qL7ZUgfo73X8$rtQTZkjvm8phhoqGC1efRjgw1$j6JIM=.#=zGa9hjsf$dbFqBrC5h4ixB$3GEVO49EelnJhzuXI=(Object #=zNme$S1Q=, UInt32 #=zoo4tB6U=)
en #=qL7ZUgfo73X8$rtQTZkjvm8phhoqGC1efRjgw1$j6JIM=.#=zclevl1al7Pt6tsNk_4xfcWsXYtM5PK5SphG_OlA=()
en #=qL7ZUgfo73X8$rtQTZkjvm8phhoqGC1efRjgw1$j6JIM=.#=zX5DPxwYXsBlZM4an$pC8ePIf59ApMV6w0Ry$JgNnsm5E()
en #=qL7ZUgfo73X8$rtQTZkjvm8phhoqGC1efRjgw1$j6JIM=.#=zYUM9BCDNZiUdqwZ6uVfLqaaQF2YswfI3W1wmfqaprSNE(Object[] #=zNme$S1Q=, Type[] #=zoo4tB6U=, Type[] #=zX2n47KU=, Object[] #=zH4UcPJg=)
en #=qL7ZUgfo73X8$rtQTZkjvm8phhoqGC1efRjgw1$j6JIM=.#=zkuW88_CV$bQ6mEUu0c$X1ZDwnFKHifm$aqlvsew=(Stream #=zNme$S1Q=, String #=zoo4tB6U=, Object[] #=zX2n47KU=, Type[] #=zH4UcPJg=, Type[] #=zYB2x5fw=, Object[] #=zI3NibOQ=)
en #=qL7ZUgfo73X8$rtQTZkjvm8phhoqGC1efRjgw1$j6JIM=.#=zGdzvEWJumHbo$WZIa9K0cYfNylS$Kz110Q==(Stream #=zNme$S1Q=, String #=zoo4tB6U=, Object[] #=zX2n47KU=)
en #=qL7ZUgfo73X8$rtQTZkjvm8phhoqGC1efRjgw1$j6JIM=.#=zITC7_BkIVgTKAkTJNcRJt9aO72Zf(Stream #=zNme$S1Q=, String #=zoo4tB6U=, Object[] #=zX2n47KU=)
en #=zSpBzj2qCi2xN0u_p1IRAyCUR8gFy.#=zqeObXkA=()
en System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
en System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
PostPosted: Tue Mar 05, 2019 12:51 am
I see your video card is listed as "Microsoft Basic Render Driver". That means you don't have the vendor's driver for your video card installed. Please install the latest graphics driver.
PostPosted: Tue Mar 05, 2019 3:11 pm
I will have to work on version 2.x because it is not compatible with my card version 3.x and 4.x
How can I export videos from iPi Recorder X in version 2.x of iPi Mocap Studio?
PostPosted: Tue Mar 05, 2019 3:13 pm
Will there be a version 3.x or 4.x that does not require Direct 11?
PostPosted: Tue Mar 05, 2019 6:10 pm
I kinda doubt they'll support it. The Geforce 8400 series came out about 12 years ago, which is pretty old by computer hardware standards.
Would it be possible to upgrade the card? A recent Geforce card isn't necessarily expensive. Just make sure the specs are compatible.
PostPosted: Fri Mar 08, 2019 6:47 am
No, we're not going back :) Our software relies on some new features in DirectX 11.
FYI even if it worked you'd get too low process speed with it. Practically any modern card will perform better.
PostPosted: Mon Mar 11, 2019 3:26 pm
Ok, will I acquire a card that supports directx 11 this month, also supports directx 12?
But while I do it, I would like you to help me take advantage of the 2.x versions of your tools, how do I do the recording and the animation ?, I can not export the video in Studio 2.x
PostPosted: Mon Mar 11, 2019 4:09 pm
I don't work for iPi Soft but I believe all of the info below is accurate:
I don't think 2.x is available for new users. The installers are online as a courtesy to users who purchased this version years ago and still have their licenses.
If you're testing Mocap Studio for the first time, you'll want to download the latest version. When you first install it, the sofware will be in 'trial' mode and you'll get all the features of Basic for 30 days. After that period is over, you can use Mocap Studio only in 'demo' mode which does not export data. At this stage, you'll need to buy a perpetual license or a subscription to gain access to all the features again.
Obviously, you should avoid activating the trial until you're ready to start testing the software.
PostPosted: Mon Mar 11, 2019 11:41 pm
That's correct.
Thanks @Greenlaw for jumping in ;)
PostPosted: Tue Mar 12, 2019 10:55 am
So what is that? http://ipisoft.com/download-2-x/
