http://forum.ipisoft.com/
Can you use Xbox One Kinect with Xbox 360 Kinect on same pc?
http://forum.ipisoft.com/viewtopic.php?f=5&t=10138
Author:  wapeddell [ Sun Jun 16, 2019 2:47 pm ]
Post subject:  Can you use Xbox One Kinect with Xbox 360 Kinect on same pc?
I'm inquiring about seeing if it's possible to use Xbox One Kinect with Xbox 360 Kinect on the same PC? If not would you have to acquire two licenses to use the different connects on two separate PCs? I do have two PCs capable of running iPi Motion Capture and iPi recorder, however, I just want to know if you can use the same license on both PCs?
Author:  vmaslov [ Sun Jun 16, 2019 4:25 pm ]
Post subject:  Re: Can you use Xbox One Kinect with Xbox 360 Kinect on same
You cannot mix Kinect 1 and Kinect 2 in the same video because they have different resolutions.
Author:  wapeddell [ Sun Jun 16, 2019 8:16 pm ]
With that being said is it possible to use the same license on another pc and do a dual capture? I have two PCs and I need know.
Author:  vmaslov [ Mon Jun 17, 2019 6:12 am ]
You didn't get me. It's not a matter of whether you record from one PC or distributed. Anyway, to process data from both Kinects in a single capture you need them to be in one video file. And that's only possible if they have the same video resolution.
Speaking of licensing - no license is needed for recording process. You can install iPi Recorder and use it for recording on any number of PCs.
