It is currently Tue Aug 11, 2020 12:40 pm
PostPosted: Fri Dec 13, 2019 9:41 pm
I have been attempting to get two Kinect V2 sensors to work in unison on one PC using UsbDk drivers. Because the USB 3.0 ports on the PC were struggling to process the data coming from the Kinects (low frame rates and freezing, occasionally got a windows warning that not enough USB resources were available) I got a 10gbps PCI express card to attempt to fix this problem.
When a Kinect is plugged into the card immediately after restarting the computer, the sensor works great, running at a solid 30 fps. However, once the stream is stopped and then started again, the feed from the Kinect is black with the message "Could not start stream". Any subsequent attempts to start recording fail until the computer is restarted again.
Any advice on how to fix this problem would be very appreciated!
PostPosted: Mon Dec 16, 2019 3:13 am
Have you also tried with an alternative libusbK driver?
Users browsing this forum: Google [Bot] and 4 guests
