http://forum.ipisoft.com/
Setup issue for Distributed Recording.
http://forum.ipisoft.com/viewtopic.php?f=5&t=10260
Author:  shoiko [ Fri May 01, 2020 5:29 am ]
Post subject:  Setup issue for Distributed Recording.
I am using Dual Kinect V2s, I have the firewall on both PCs disabled, all antivirus software disabled and the application ran as administrator just in case. I have my PC and the Laptop both connected via Ethernet. When I set either as a slave and attempt to connect to slave the list shows nothing. I can ping both machines from each machine. Using iPi Recorder 4.4.5.82.
Do I need iPi Mocap Studio trial installed first? I'm trying to make sure the recording phase is working before activating the trial.
Author:  vmaslov [ Fri May 01, 2020 12:46 pm ]
Post subject:  Re: Setup issue for Distributed Recording.
Probably something blocking the traffic still sits there unnoticed.
Try connecting PCs via WiFi hotspot instead.
