It is currently Tue Oct 27, 2026 4:44 pm
PostPosted: Tue Aug 14, 2012 4:48 am
This little problem is very irritating, its been intermittent, but now after trying different set-ups and kinects its certainly seems a software issue:
When I have 2 kinects plugged in, they (sometimes) seem to get mixed up. For example; The elevation angle control in properties for camera 1 controls the elevation angle of camera 2 and vice versa.
Now that the the camera properties screen fills the entire screen (although the only control you have with kinects is the elevation) you cannot see what camera 2 is seeing until you flip back to set-up; its all so time consuming to keep having to flip to the properties of one camera to adjust the elevation of the other camera.
I have the 2 kinects connected by un-powered usb extension cables, could this have something to do with it? I say this as it was all working ok this morning camera 1 was camera 1 in properties etc. I then moved one of the cameras (camera 1) added a usb extension, restarted machine, and now the camera properties are elevating the opposite cameras. Weird but true.
Please can you have a look at this, I have had this problem a few times in the past. Cant we just have the kinect elevation control in the dual camera view window, it would save a lot of time.
Rob
PostPosted: Mon Sep 10, 2012 1:12 am
We could not reproduce this issue.
Do you experience it with both Kinect for XBOX and Kinect for Windows (you've mentioned that you tried different Kinects)?
What drivers do you use: Kinect SDK or PrimeSense?
PostPosted: Sun Nov 25, 2012 12:06 pm
Fixed in version 2.1.1.18.
