I recall seeing similar errors with Kinect for Windows. I think restarting the computer cleared that up but I also saw this error with a Kinect that had gone bad. Hopefully, the restart is all you need. Also, try switching to a different USB port or controller.
Kinect for XBox should be compatible with Kinect SDK 1.8. I normally use three Kinect for Windows but I recently had to use an XBox Kinect as a temporary replacement, and it worked fine with Mocap Studio 3.
This is on Windows 7--are you on 7 or 8? I'm not sure if Kinect for XBox works with Windows 8 or if it requires different drivers.
