It is currently Fri Feb 15, 2019 4:54 pm
PostPosted: Sat Aug 08, 2015 4:04 am
This is quite tedious, I used Mocap Studio 3 before and worked fine, but since an update or something it won't start anymore.
Keeps giving this error and shutting down, I even tried formatting my computer and re-installing everything but no avail.
Would be really nice if you guys could fix this issue, cause it basicly makes it impossible to work with.
This is the error Log :
iPi Mocap Studio version 3.2.2.189 [<unknown>]
ENVIRONMENT
OS: Microsoft Windows NT 6.3.9600.0 (64 bits)
.NET: 4.0.30319.42000
CPU count: 4
GPU Information:
NVIDIA GeForce GTX 560 (VendorID=10DEh, DeviceID=1201h, SubsystemID=23261462h, Revision=A1h)
Memory: 973 MB dedicated video + 0 B dedicated system + 3,0 GB shared system
Outputs: (1920x1080@60 R8G8B8A8_UNorm)
Intel(R) HD Graphics 3000 (VendorID=8086h, DeviceID=112h, SubsystemID=D0001458h, Revision=9h)
Primary: no, Integrated: yes, Compatible: yes, In Use: yes
Memory: 32 MB dedicated video + 0 B dedicated system + 1,6 GB shared system
PROCESS
GC: Workstation (Interactive)
Running in 64 bits
EXCEPTION
SharpDX.SharpDXException: HRESULT: [0x80070057], Module: [General], ApiCode: [E_INVALIDARG/Invalid Arguments], Message: The parameter is incorrect.
at SharpDX.Result.CheckError()
at SharpDX.Direct3D11.Device.CreateComputeShader(IntPtr shaderBytecodeRef, PointerSize bytecodeLength, ClassLinkage classLinkageRef, ComputeShader computeShaderOut)
at SharpDX.Direct3D11.ComputeShader..ctor(Device device, Byte[] shaderBytecode, ClassLinkage linkage)
at SharpDX.Toolkit.Graphics.EffectPool.GetOrCompileShader(EffectShaderType shaderType, Int32 index, Int32 soRasterizedStream, StreamOutputElement[] soElements, String& profileError)
at SharpDX.Toolkit.Graphics.EffectPass.InitStageBlock(StageBlock stageBlock, Logger logger)
at SharpDX.Toolkit.Graphics.EffectPass.Initialize(Logger logger)
at SharpDX.Toolkit.Graphics.Effect.InitializeFrom(Effect effectDataArg, Effect cloneFromEffect)
at SharpDX.Toolkit.Graphics.Effect.CreateInstanceFrom(GraphicsDevice device, EffectData effectData, EffectPool effectPool)
at SharpDX.Toolkit.Graphics.EffectContentReader.ReadContent(IContentManager readerManager, GraphicsDevice device, ContentReaderParameters& parameters)
at SharpDX.Toolkit.Graphics.GraphicsResourceContentReaderBase`1.SharpDX.Toolkit.Content.IContentReader.ReadContent(IContentManager readerManager, ContentReaderParameters& parameters)
at SharpDX.Toolkit.Content.ContentManager.LoadAssetWithDynamicContentReader(Type assetType, String assetName, Stream stream, Object options)
at SharpDX.Toolkit.Content.ContentManager.Load(Type assetType, String assetName, Object options)
at SharpDX.Toolkit.Content.ContentManager.Load[T](String assetName, Object options)
at #=qPSucPdk8tBq37271$2SxsZKbatzuaPKcFicyyVgAXxMGPjxQMS6zTIS1KPCImrY$BIEA$JoGbLUMoxn3xJjK0g==.Load[T](String #=qsPjvHcuSQKEAJbLJN7f8Ow==, Object #=qimlRBkxaapqrw17huY71_A==)
at #=qbEsfxLcyigZalKm2haif67BBbjASCOM87iEXHvy7APJ_V604ffDRqWZTp2zfraXY..ctor(ContentManager #=qoDbr5jY_u1G0Dk19lMvPrA==, Int32 #=qg319mTr4iAMmZ$JeKcpwHIDIAhaBQIY4b5HutU8oBHA=, Int32 #=qNf0kH8oyvZsXRo5bWNz67Q==, Texture2DBase #=qhQ7auaY1N0IYMm$ux6YntdS2XZO83B_QcL$LOvmI_zs=, Int32 #=qICcLLqdJBqUbQSunNEhU5w==, Int32 #=qyZ23MgAhBmbUH2Z9$TuoOw==)
at #=qx49y0AaLGFZoh9jX96ppco$M2LVlT0gEkEQ9EujCg$u8gN6WfXpIgNlkZD6jcv0SGsHl0TrRIgsdOgEMJRnrsw==..ctor(#=qqAp3v9uO13MrY8CZvuU15pS1IiIgWX8Tau10JD36OyTXL5wIYsjJuNgoYg1Xk9pg #=qS6n2vnSgJdnJUn8Eo0XP3A==, ContentManager #=qoDbr5jY_u1G0Dk19lMvPrA==, Int32 #=qa6ZUgsrPXAjVmysll1ADEw==, Boolean #=quGX9ns00S78U65ks8$LmCB5M$hA1nyfTZFQDX9NV07k=, Int32 #=q3r7BTBE056zX5I_3RjjfWqQeZbyQL99tC6Y0HUknqKw=, String[] #=qROYVk3Kwt7Mel0mhRpf2sg==)
at #=qvQeX7CoodJDijP1$sHlVtWQ3avRKbhkB7h241sGQ6bxvMRndLgNB0_fbitOZeK_QL9AxIAVr8ResuhDS9xgTsA==..ctor(#=qqAp3v9uO13MrY8CZvuU15pS1IiIgWX8Tau10JD36OyTXL5wIYsjJuNgoYg1Xk9pg #=qA6_u2CEyzT7v2e4D8EL7cg==, ContentManager #=qdwjt$qcnRll00CR_c4wzDg==, Int32 #=q5MIn5Zg2S7hUsEX0sITHcQ==, String[] #=qROYVk3Kwt7Mel0mhRpf2sg==, Int32 #=q3r7BTBE056zX5I_3RjjfWqQeZbyQL99tC6Y0HUknqKw=)
at #=qGNx3Dwn5sb$74bdc9Z8ATOLiEXv21GTORhSKjcptK8KG$N1WdHhNT2YXpoSZn$Gnv880raR1yHPqvp_0LVRMhw==..ctor(#=qqAp3v9uO13MrY8CZvuU15pS1IiIgWX8Tau10JD36OyTXL5wIYsjJuNgoYg1Xk9pg #=qA6_u2CEyzT7v2e4D8EL7cg==, ContentManager[] #=q2gXeko7uZdO1aD9r8hO$ItUxuR1GNSzmcn2$LaJsirc=, Int32 #=q5MIn5Zg2S7hUsEX0sITHcQ==, String[] #=qROYVk3Kwt7Mel0mhRpf2sg==, Int32 #=q3r7BTBE056zX5I_3RjjfWqQeZbyQL99tC6Y0HUknqKw=)
at #=qwx1$tal1$2z_4xgdKtXy4$KZE$pm9AcVatsN8JGBkhJd33UR0cGc9zuuVUE8OIX4..ctor(#=qg2xaMwDxWJ5DllI9ptOZpd2Jl9EfgHsMv1RBqGFUzMItrfBQsbT5aRwglYES$B3$ #=quPW8hYVDs72ZDIq4ck9spA==, Int32 #=q5MIn5Zg2S7hUsEX0sITHcQ==, String[] #=qROYVk3Kwt7Mel0mhRpf2sg==)
at #=qNFPIaMBTVhYMRtVDkeu_dGEBTi7JAWyq1YEfdZ4Orj0xxAt9ZV7N9wtZL1MbxhiTZFBLuK1c2xOb8Xjr6OBnzA==..ctor(#=qg2xaMwDxWJ5DllI9ptOZpd2Jl9EfgHsMv1RBqGFUzMItrfBQsbT5aRwglYES$B3$ #=quPW8hYVDs72ZDIq4ck9spA==)
at #=qg2xaMwDxWJ5DllI9ptOZpd2Jl9EfgHsMv1RBqGFUzMItrfBQsbT5aRwglYES$B3$.#=q_oErp0y0RLQNqRsCdy3f8PKKMku2PCICrghl35cuxf8=()
at #=qg2xaMwDxWJ5DllI9ptOZpd2Jl9EfgHsMv1RBqGFUzMItrfBQsbT5aRwglYES$B3$.#=qWBw6$$KLeH9rsckMR5G6_w==()
at -.dje_q4HQRLFH2NDFQDFR57CKUMV24YBHBMDSQLU3QAJFDZBH4CJTC7Y6HQQLBBNGKN94KGG3DB7NE4G4C5_ejd.#=qDlAVOcDCk5IeuVZcQXdpRL5YEAP1WF8XdfXWbWTTbW4=()
at -.dje_qRS4M3LFJTAMLUKNJX9YC3GPUD37E5NCSCUTKVHAEB23D3ADWYWAA_ejd.dje_q8QMCEQM3G7UWKFX9XBPCACBWYLEQPXR62WF2ZWRYQK5W3D3MF7JQ_ejd(Object #=qRiXPt74dRSdtx_WeXQf4Iw==, RoutedEventArgs #=q$Ai3H5w3hQm6DeMCEky38A==)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.BroadcastEventHelper.BroadcastEvent(DependencyObject root, RoutedEvent routedEvent)
at System.Windows.BroadcastEventHelper.BroadcastLoadedEvent(Object root)
at MS.Internal.LoadedOrUnloadedOperation.DoWork()
at System.Windows.Media.MediaContext.FireLoadedPendingCallbacks()
at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
at System.Windows.Interop.HwndTarget.OnResize()
at System.Windows.Interop.HwndTarget.HandleMessage(WindowMessage msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Interop.HwndSource.HwndTargetFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
PostPosted: Sat Aug 08, 2015 6:50 am
Try removing the values GPU Hardware and GPU Selection from this registry key:
HKEY_CURRENT_USER\SOFTWARE\iPi Soft\iPi Mocap Studio 3
PostPosted: Sat Aug 08, 2015 2:33 pm
I tried and erased the GPU Hardware value but couldn't find the GPU Selection.
Still getting the same error :
Thanks for the response though.
PostPosted: Sun Aug 09, 2015 1:25 am
OK then, it seems that Mocap Studio falsely detects that Intel HD3000 supports DirectX 11 while it does not. We'll make improvements to detection.
In the meanwhile, if you don't use the integrated HD3000 GPU for other apps, try to disable it. First in Device Manger (right click > Disable). If it does not helps, then look for corresponding setting in BIOS.
PostPosted: Sun Aug 09, 2015 2:19 am
Ok that seemed to do the trick ! Thank you very much.
