ipisoft.com
http://forum.ipisoft.com/
An unexpected error occurred in the application.
http://forum.ipisoft.com/viewtopic.php?f=5&t=9432
Page 1 of 1
Author:  gamecard [ Tue Sep 01, 2015 2:56 pm ]
Post subject:  An unexpected error occurred in the application.
iPi Mocap Studio version 3.2.4.191 [FREE TRIAL (29 days left)]
ENVIRONMENT
OS: Microsoft Windows NT 10.0.10240.0 (64 bits)
.NET: 4.0.30319.42000
CPU count: 8
GPU Information:
AMD Radeon R9 200 Series (VendorID=1002h, DeviceID=679Ah, SubsystemID=A003174Bh, Revision=0h)
Primary: yes, Integrated: no, Compatible: yes, In Use: yes
Memory: 3,0 GB dedicated video + 0 B dedicated system + 5,0 GB shared system
Outputs: (1920x1080@50 R8G8B8A8_UNorm)
PROCESS
GC: Workstation (Interactive)
Running in 64 bits
EXCEPTION
System.IO.FileFormatException: This version of DMX importer does not support binary files
Server stack trace:
bei #=q$fvyyBz_burV6NrQhtmagLrhvP_fcPHTKstBocnK06Hu9LJiLL9x0hkpshafEjQwwLZwEf65lEiIBgSczp6v8A==.#=qK0YslOAptyQjCzcfQR6W7A==(Stream #=q7QkOWwaX6lpQ7S21wEHqZA==)
bei #=qQ34eNXVv4mSuqVziIYTztejZvPBbmrTpl1clNTDi2jYxCSqqCkivPSfCfAQR4sL$lvg9fFVYUT0Xbc2ov17QEg==.#=qiqvgSFKXjpzdAz73WVQwhQ==(Stream #=qKM5O_CUpq5euhgGyMEef8A==, GraphicsDevice #=qveMnOZjxeCJKdIxYIkblCw==)
bei #=qJFiKwzxwS9TNuIpJcfRdoTnH9OPxYFiCx9nkoHoIa4cxO5ejAOSBVH6NBRaJTqBYKOaZSiquLRTxNU5YQbX8rw==.#=qiqvgSFKXjpzdAz73WVQwhQ==(String #=q0hS70oIBScVmr_Wrrlm_BA==, GraphicsDevice #=qveMnOZjxeCJKdIxYIkblCw==)
bei #=qQ34eNXVv4mSuqVziIYTztejZvPBbmrTpl1clNTDi2jYxCSqqCkivPSfCfAQR4sL$lvg9fFVYUT0Xbc2ov17QEg==.#=qiqvgSFKXjpzdAz73WVQwhQ==(String #=q0hS70oIBScVmr_Wrrlm_BA==, GraphicsDevice #=qveMnOZjxeCJKdIxYIkblCw==)
bei #=qYKT7SwCLsLGrDXZORtWkwc72arPfpwWyxNhvggbtJXjzbkTTvJuLciBPPxBYgS__.#=q2sit3gb9iFHzxEVIaQxd6dPl9F84oUwjIT$VzWNImUE=.#=qEerQ81acVQdns50CdbP5EVSLARB_1LMRGHAOpyTyeDA=()
bei System.Windows.Threading.DispatcherOperation.InvokeDelegateCore()
bei System.Windows.Threading.DispatcherOperation.InvokeImpl()
--- Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde ---
bei System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
bei System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
bei System.Windows.Threading.DispatcherOperation.Wait(TimeSpan timeout)
bei #=qYKT7SwCLsLGrDXZORtWkwc72arPfpwWyxNhvggbtJXjzbkTTvJuLciBPPxBYgS__.#=q2sit3gb9iFHzxEVIaQxd6dPl9F84oUwjIT$VzWNImUE=.#=qYOZJ8LLqbKER0ey_Q7Lvr9KAjsyW3zYSBqFWZa5kVvc=()
bei System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs)
bei System.Runtime.Remoting.Messaging.StackBuilderSink.AsyncProcessMessage(IMessage msg, IMessageSink replySink)
Exception rethrown at [0]:
bei System.Runtime.Remoting.Proxies.RealProxy.EndInvokeHelper(Message reqMsg, Boolean bProxyCase)
bei System.Action.EndInvoke(IAsyncResult result) bei #=qB3Sv7cZi2dX2yZWGb9YItnZiIXozIyrC5DQAqhSQ1Ig=.#=qad03BhClfyVI7raIJVgnFdP9uTtHVJL1jmEPA7p5qOc=(MethodBase #=qrPlWyfMi4NSc7ke5OE0mlA==, Boolean #=qgDDfQ6ZBz5Q2U$emTS3Vhg==)
bei #=qB3Sv7cZi2dX2yZWGb9YItnZiIXozIyrC5DQAqhSQ1Ig=.#=q7Bd1oreOtTEhh1bQHB6zkmuno1Y0jVa9PaOarnW0gnM=()
bei #=qB3Sv7cZi2dX2yZWGb9YItnZiIXozIyrC5DQAqhSQ1Ig=.#=qPFEqeFs$1usueMP5C3hExw==() bei #=qB3Sv7cZi2dX2yZWGb9YItnZiIXozIyrC5DQAqhSQ1Ig=.#=qau9jEOaWbsy4JNnKRYQXuokh3fUbTz6D_8Qo7odVScU=(Object #=qrPlWyfMi4NSc7ke5OE0mlA==)
bei #=qB3Sv7cZi2dX2yZWGb9YItnZiIXozIyrC5DQAqhSQ1Ig=.#=qNU_nIY2sb749BBjozJB3LEtu$$E7$33dmbzuBZLOvKY=(#=qdyzkL5ImHi_WIw_kE_G40WuAa40x61MB_Npka0sdVkY= #=qrPlWyfMi4NSc7ke5OE0mlA==)
bei #=qB3Sv7cZi2dX2yZWGb9YItnZiIXozIyrC5DQAqhSQ1Ig=.#=quMKBXwQglu8xVnF3k3_CJx45o5pDs_rCBZZduCRjmg0=()
bei #=qB3Sv7cZi2dX2yZWGb9YItnZiIXozIyrC5DQAqhSQ1Ig=.#=qt3j1eQLeQVG3xRw5Ys7TA0aPIduAcqz84vALGghWOw0=()
bei #=qB3Sv7cZi2dX2yZWGb9YItnZiIXozIyrC5DQAqhSQ1Ig=.#=q1IlFO8xayCvb9TFEJ5KJn34WULHUJq9FSj8ShFFBYxA=() bei #=qB3Sv7cZi2dX2yZWGb9YItnZiIXozIyrC5DQAqhSQ1Ig=.#=qau9jEOaWbsy4JNnKRYQXuokh3fUbTz6D_8Qo7odVScU=(Object #=qrPlWyfMi4NSc7ke5OE0mlA==)
bei #=qB3Sv7cZi2dX2yZWGb9YItnZiIXozIyrC5DQAqhSQ1Ig=.#=q1d$_7XrqdFe9AFouwDVa6ibQ9SXw72WVKeECek5cv7g=(Object[] #=qrPlWyfMi4NSc7ke5OE0mlA==, Type[] #=qgDDfQ6ZBz5Q2U$emTS3Vhg==, Type[] #=qfoyDlbw5usOGIsHitD8yQw==, Object[] #=qPH0upqA1xIccUuRHyvgeyA==)
bei #=qB3Sv7cZi2dX2yZWGb9YItnZiIXozIyrC5DQAqhSQ1Ig=.#=qPh$kMZohXydZ34sgkhjg5DcrIhL0TvXrOugkWNPouHk=(Stream #=qrPlWyfMi4NSc7ke5OE0mlA==, String #=qgDDfQ6ZBz5Q2U$emTS3Vhg==, Object[] #=qfoyDlbw5usOGIsHitD8yQw==, Type[] #=qPH0upqA1xIccUuRHyvgeyA==, Type[] #=qrK6kzK7II4GBHL3OUQm7Cg==, Object[] #=qQJe1Zid$ViqoZJ_v4HS7jw==)
bei #=qB3Sv7cZi2dX2yZWGb9YItnZiIXozIyrC5DQAqhSQ1Ig=.#=qV6ZT28v0Ov_H9xHRSaKTMLhApOe1Hi8LNp3_MSyW6kY=(Stream #=qrPlWyfMi4NSc7ke5OE0mlA==, String #=qgDDfQ6ZBz5Q2U$emTS3Vhg==, Object[] #=qfoyDlbw5usOGIsHitD8yQw==)
bei #=qB3Sv7cZi2dX2yZWGb9YItnZiIXozIyrC5DQAqhSQ1Ig=.#=qmg35peyopBZHLFNeUKpdAd3SLZuNZXXKYe_$lVtsHIw=(Stream #=qrPlWyfMi4NSc7ke5OE0mlA==, String #=qgDDfQ6ZBz5Q2U$emTS3Vhg==, Object[] #=qfoyDlbw5usOGIsHitD8yQw==)
bei -.dje_qNHHYGNCXP6HF25BPVR3TPE6KW3ANJSUC4F3FE83KR8TDELL5W43N6BPKF8TLXN8JJZ5YS2N6ZFX9D_ejd.#=qHdtt_inFPqretGnKP8rAczOHlfeLCMaGvvFtXb7bbP8=(IAsyncResult #=qQ764t9XKiSEy5bmy5woghA==)
bei System.Runtime.Remoting.Messaging.AsyncResult.SyncProcessMessage(IMessage msg)
bei System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
bei System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
bei System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
bei System.Threading.ThreadPoolWorkQueue.Dispatch()
i export the animation from source filmmaker as .dmx file but this .dmx file crash iPi Mocap Studio 3
the file https://www.dropbox.com/s/whptkipfsa7aacp/yrel.dmx?dl=0
Author:  vmaslov [ Wed Sep 02, 2015 1:37 am ]
Post subject:  Re: An unexpected error occurred in the application.
Hello
Thanks for reporting this error
Currently, iPi Mocap Studio does not support binary DMX files, only text ones. There should be an option in SFM to write DMX in text format.
Nevertheless, the app should not crash on unsupported file format. We'll fix that in the next release.
http://www.phpbb.com/
