It is currently Wed Jul 17, 2019 10:27 pm
Post a new topicPost a reply Page 3 of 3   [ 28 posts ]
Go to page Previous  1, 2, 3
PostPosted: Sat May 25, 2019 2:29 pm
kanakas wrote:
I've got a similar problem - low framerate, on a very high spec laptop with the latest Kinect sensor. Anyone else got any ideas?
the skeletal data of the subject using the depth stream however, its frame rate is only around 5-7 fps.
Postec my phenq review https://enfinmince.fr/phenq-avis/
PostPosted: Tue May 28, 2019 1:56 am
Have you tried all available USB ports for connecting Kinect?
PostPosted: Tue May 28, 2019 3:12 am
multi kinect2.0 the frames of sensor about 15fps when use the
driver
PostPosted: Mon Jun 24, 2019 2:12 pm
kanaka wrote:
I have a similar problem. Have 3x Kinect 2 depth sensor configuration. 2 of the depth sensors are on lower spec hardware, yet they have no problems maintaining a close to 30fps frame rate. One of the 3 sensors is running on a new Alienware R4 i7 16GB RAM, PCI-SSD, GeForce 1060 laptop, and it sometimes struggles to achieve 25fps. Sometimes a clean reboot and having absolutely no other apps running helps, sometimes not. Not clear to me where the bottleneck is. Any suggestions welcome.
I have also faced this problem where one of the 3 sensors were running on a new Alienware R4 i7 16GB RAM, PCI-SSD, GeForce 1060 laptop, and many times it used to struggles to achieve 25fps. Don't know why. Any reason .
PostPosted: Wed Jun 26, 2019 6:20 am
Some suggestions
  • Try all available USB ports.
  • Ensure both iPi Recorder app and KinectService.exe process are running with discrete GPU.
  • Try disabling swap file.
  • Try using libfreenect2 instead of Kinect SDK.
PostPosted: Mon Jul 01, 2019 10:56 am
Even I have got a similar problem - low framerate, also on very high spec laptop with the latest Kinect sensor. Any update on this .
PostPosted: Wed Jul 03, 2019 3:30 pm
I need to track the skeletal data of the subject using the depth stream however, its frame rate is only around 5-7 fps.
PostPosted: Thu Jul 04, 2019 10:04 am
Have you tried suggestions from my above post?
