It is currently Sat Aug 15, 2020 9:40 am
PostPosted: Fri Oct 28, 2016 11:50 pm
I get this error message every time i click the "Track Forward" button
iPi Mocap Studio version 3.4.12.208 [FREE TRIAL (30 days left)]
ENVIRONMENT
OS: Microsoft Windows NT 10.0.10240.0 (64 bits)
.NET: 4.0.30319.42000
CPU count: 4
GPU Information:
NVIDIA GeForce 940MX (VendorID=10DEh, DeviceID=134Dh, SubsystemID=11901462h, Revision=A2h)
Memory: 2.0 GB dedicated video + 0 B dedicated system + 2.0 GB shared system
Outputs: (1366x768@48 R8G8B8A8_UNorm)
Intel(R) HD Graphics 530 (VendorID=8086h, DeviceID=191Bh, SubsystemID=11901462h, Revision=6h)
Primary: no, Integrated: yes, Compatible: yes, In Use: no
Memory: 128 MB dedicated video + 0 B dedicated system + 2.0 GB shared system
Outputs:
PROCESS
GC: Workstation (Interactive)
Running in 64 bits
EXCEPTION
System.NullReferenceException: Object reference not set to an instance of an object.
at #=qgibgPApwkyzqYDCQorqCIiX9wJQFkCbMf6coLMT1xyg5IphwcycUXSwcHO1gXgf6s7jMQ61Nbf2sFPIvHlYu_A==.#=qsH4S3aZXEV7_zDCTtwpl1Q==()
at #=qw8pH7nxKic0OsVEFZ$1EQ75szc$DL9DXk9FhP05rc_JC9Zz2EHL7qj1W0uXJ0q3506ar5LAyJKKJUOWK4toIgw==.#=qsH4S3aZXEV7_zDCTtwpl1Q==()
at #=qRohwsI7Oj_AV5SF$TYOO7O4hwlOupm59hOaa8B$LDYar9$0lV4eri4l1EgX65k5HCLQhtgbIUFd1Tq0mtNfB_Q==.#=qsH4S3aZXEV7_zDCTtwpl1Q==(Boolean #=qVBwJ1m3NSjySAZAtuUA8ow==, Boolean #=qLXCGOrpSsT4DE3$y2G2f4y$Z7uAnhof7QtSXwSVEmGY=, Boolean #=qKdXjESxhiEF9j7oOMzmvPg==)
at #=qbwIadl_3bsOwRrS6esB2ORh$MYsDc$aR4HwfleCdI3YYSYae3rqAPxHtsVQ3qF4y.#=qyw71STyV8IKYbnP9PER1TA==(Boolean #=qVBwJ1m3NSjySAZAtuUA8ow==, Boolean #=qKdXjESxhiEF9j7oOMzmvPg==)
at -.dje_qN9TBTEX6R39WU3A4769AG8QZCAMTN6FYLJCTFU9WCQP2HZ2TPD8A_ejd.#=qwdIPPcFxbmPQyqJ1Z8i0nRyBUAnmMdBFAw86QpWOnjs=(Object #=qFUO15AjppCtyaAN1iStlhA==, RoutedEventArgs #=qvFr9YKade4k3hAbGln0vVQ==)
at System.Windows.Input.CommandBinding.OnExecuted(Object sender, ExecutedRoutedEventArgs e)
at System.Windows.Input.CommandManager.ExecuteCommandBinding(Object sender, ExecutedRoutedEventArgs e, CommandBinding commandBinding)
at System.Windows.Input.CommandManager.FindCommandBinding(CommandBindingCollection commandBindings, Object sender, RoutedEventArgs e, ICommand command, Boolean execute)
at System.Windows.Input.CommandManager.FindCommandBinding(Object sender, RoutedEventArgs e, ICommand command, Boolean execute)
at System.Windows.Input.CommandManager.OnExecuted(Object sender, ExecutedRoutedEventArgs e)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.Input.RoutedCommand.ExecuteImpl(Object parameter, IInputElement target, Boolean userInitiated)
at MS.Internal.Commands.CommandHelpers.CriticalExecuteCommandSource(ICommandSource commandSource, Boolean userInitiated)
at System.Windows.Controls.Primitives.ButtonBase.OnClick()
at System.Windows.Controls.Button.OnClick()
at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
at System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
PostPosted: Mon Oct 31, 2016 5:11 am
could you please let us know what kind of project you have (which cameras / sensors and how many)?
Do you have this issue on the same project or on different projects?
As a workaround, you can use previous version of tracking.
Please go to 'Tracking' tab, open 'Advanced Tracking Settings' at the bottom, and check 'Use old tracking algorithm' checkbox.
This option is project-specific, so need to be set in all projects.
