It is currently Wed Feb 26, 2020 11:07 pm
PostPosted: Wed May 31, 2017 10:57 am
I've been using a 3 Kinect setup with Mocap Studio v2 successfully. I am testing the evaluation version of v3, but no matter how many times I do the calibration, it fails miserably. Is there some different requirement? I use the same mini mag light with the bulb bare.
I tried about 10 times in Recorder v3 and MS v3. It failed on occlusions, good frame count, marker cloud side etc, different each time, usually multiple issues.
Next I recorded a calibration video in Recorder v2, and ran calibration in MS v2 and it worked. I then took the same recording from v2 and opened it in MS 3. It calibrated successfully. I think I am encountering an issue with recorder v3.
Adnan
http://www.madguru.com
PostPosted: Wed May 31, 2017 2:28 pm
I see you've already tried to process successful calibration records from v2 with v3. That is the first I'd like to ask you.
Now, can you share one of your new calibration records? I'd take a look at it.
Users browsing this forum: MSN [Bot] and 4 guests
