It is currently Thu May 23, 2019 2:46 pm
PostPosted: Fri Feb 24, 2017 3:12 pm
Not sure what the issue is. It'll work briefly then cut out and be unrecognizable and/or appear as a black screen. Then it'll only work on 320x240 resolution. Any ideas? I'm pretty frustrated. It worked fine with one kinect now it's giving me issues...
I currently have two adapters attached to the two kinects.
PostPosted: Fri Feb 24, 2017 8:31 pm
If you have RGB pic-n-pic turned on in set up, try using only depth 640x480.
PostPosted: Sun Feb 26, 2017 11:08 am
Try plugging the second Kinect into all available USB ports, checking how it works with each one.
PostPosted: Sun Feb 26, 2017 11:20 am
Yes, good point, I just took it as the sensor and port worked for individual testing before hand.
