It is currently Sat Aug 15, 2020 10:08 am
PostPosted: Fri Jul 03, 2020 8:29 am
Hi everyone,
I'm new and setting up my PS Eye Cameras in my basement. I'm wondering if it is better to setup 4 PS Eyes cameras where the actor's body is fully in view or 6 PS Eye cameras where 4 cameras will see the full body and 2 cameras will see on parts of the body? Is the partial camera helpful in this scenario? or should I eliminate it to avoid getting the software confused?
PostPosted: Fri Jul 03, 2020 8:47 am
It's better to avoid cameras which do not see the whole body. Even if for some reason you cannot position all 6 cameras in a circle so they all see an actor, you can still benefit from additional cameras. For instance, you can place 2x cameras at the same location in a room where an actor is fully visible but at much different heights. Or (depending on available height) even placing additional cameras at the ceiling looking down - this is especially helpful for crouching and crawling.
PostPosted: Fri Jul 03, 2020 10:59 am
That sounds great. I'm planning to mount 4 towards the ceiling and two at below mid level. Is it ok to mount the 4 ceiling cameras upside down? Thanks.
PostPosted: Fri Jul 03, 2020 12:16 pm
Yes, camera orientation doesn't matter for RGB tracking.
However, for your convenience there is an option for PS Eye to switch camera frame upside down thus producing non-inverted picture. Look in the toolbar at Setup screen.
PostPosted: Fri Jul 03, 2020 12:42 pm
Awesome. Thank you very much for the help.
