It is currently Sat Sep 26, 2020 4:20 am
PostPosted: Wed Aug 18, 2010 11:18 am
I know about having to put the 4 cams at a semi circle but do you get better mocap having all of them at the same height or at different heights?
thanks in advanced,
Stuckon3d
PostPosted: Wed Aug 18, 2010 11:34 am
for correct foot and shoulder tracking it is important to have at least one camera at 2+ meters height. As to others you can fix them at about 1.5 meters height. For example see slide 7 here.
Also you can follow the advises from Greenlaw:
Quote:
The setup I've been using lately seems to work very well for me: It's a half-circle arrangement, with the cameras about 2 to 3 meters up, and far back enough to see the full figure of the performer with plenty of space around him. I have to check, but I think the cameras are 4 meters or so from the performe
PostPosted: Wed Aug 18, 2010 3:16 pm
Thank you Andrew, this weekend is going to be the big test for me, im going to take my living room apart so i have some space to move around. I hope that it is enough :)
PostPosted: Tue Feb 15, 2011 3:36 am
Hi, just wondered what is the distance between the cams? im tryign to get an idea of what floorspace ill need for this, I got a room in mind (a loft conversion) but it has a white beam right in the middle! so I hope i can mound the middle cam on that and 1 either side... think it will be ok but just trying to plan this all out
