It is currently Fri Aug 14, 2020 4:51 am
 Post subject: calibration object?
PostPosted: Tue Oct 13, 2009 12:34 am
I'm a sports biomechanics student and I am making a study on big boats sailing.
I have made a camera capture on a boat with 3-4 cameras (all Sanyo Xacti WH-1) but didn't make the calibration procedure requested (using the candle light). I wanted to use skillspector or APAS for the movement reconstruction so I used a calibration object (6 points viewed by all the cameras). So I wanted to know wether ipisoft can perform a calibration with this object?
Other than that is it possible to perform calibration (with the candle light) outdoor (daytime)?
Thanks,
Daniel
 Post subject: Re: calibration object?
PostPosted: Thu Oct 29, 2009 2:58 pm
No, sorry but we only support calibration with point marker.
You should be able to calibrate with bright marker (like Mini Maglite flashlight in candle mode) outdoors in a shadow (but not in bright sunlight). You can turn down camera exposure to minimize the brightness of all extraneous objects in the scene.
