It is currently Wed Apr 24, 2019 1:34 am
 Post subject: IPA mocap 3 to Iclone 6
PostPosted: Wed May 24, 2017 10:25 am
With new version ipi mocap 3 all motion are distorted in iclone 6
I am using 3dxchnge to convert BHV to motion
With mocap 2 all works fine
I exporting from mocap in motion builder format
All was fine in version 2 but not in version 3 of ipi mocap
I need help please
PostPosted: Wed May 24, 2017 6:20 pm
Not sure what is meant by "distorted" in iClone 6, I just converted a BVH file in 3DXchange using the MoBu iPi export skeleton from iPi Studio 3 and it worked as it should.
Can you maybe explain more of the issue and what's going on for you? Screenshot of the issue maybe?
Note to iPi devs when I selected the MoBu and 3DS Max rigs:
(I did notice the MoBu and 3ds Max iPi skeletons don't line up correctly with the floor grid in iPi Studio 3 now or with the default iPi skeleton as they should, can someone at iPi take a look into this).
I personally stopped using the other export skeletons from iPi and I just retarget the iPi default skeleton now in 3DXchange using the Custom characterization and saved/load the characterization file on import of new motions to 3DXchange, but the export skeletons should line up on the floor grid in iPi Studio 3 no matter, the Endorphin and iClone ones do.
PostPosted: Thu May 25, 2017 12:06 am
I think I found my mistake
When I export mobu from ipi mocap 3 I missing check reset origin and tpose
Now it seem ok
Thanks a lot
PostPosted: Thu May 25, 2017 3:31 am
Thanks for reporting, we'll look into this.
PostPosted: Thu May 25, 2017 5:05 am
Good to read you got it working, and yes, rig needs to be returned to the T pose before export to iClone 6, or I should say that's the way I do it, never exported without to see the effect in iClone, but I am almost positive the arms would be crossed up at least.
I do know without a T pose on an imported file with 3 DS Max rig from iPi the arms will get crossed when testing a motion with preview, so if anyone is using the 3DS Max rig exported from iPi for 3DXchange, you will need to manually put the arms in a T pose, save that T pose for 3DXchange to re load later, and then convert it.
Thanks Maslov for looking at the rig position issue.
PostPosted: Sat Jun 17, 2017 11:47 am
Fixed in v3.6.4.
