It is currently Sat Feb 22, 2020 5:12 am
 Post subject: cant pair ps move
PostPosted: Thu Mar 22, 2018 11:00 am
Hi everyone first of all ı get all things for mocap. 6 ps eye 6 ext active usb cable 6 usb 3.0 pci driver. 3 ps move 1 ps charcger dock. 1 bluetotth 4.0 dongle
Cameras work fine but cant pair the ps moves. I installed bluetooth driver open the ipi recorder open=> new drivier => ps move , and its say connect your move with usb. ı connected ps move but nothing changes . Pc doesnt give any response. I tried ps move services. SRC . Motioninjoy(maybe closed ). can anyone help.
 Post subject: Re: cant pair ps move
PostPosted: Thu Mar 22, 2018 2:23 pm
If you've got PS Move of a new modification then probably they are not supported by iPi Recorder yet.
Please look at the back label of PS Moves. What is the model number? Is it the same as in this discussion?
viewtopic.php?f=5&t=9899
PostPosted: Thu Mar 22, 2018 11:15 pm
My ps moves model number = CECH-ZCM1E
PostPosted: Fri Mar 23, 2018 2:32 am
So this is not a new model.
Please try to uninstall MotioninJoy if it's still installed and run pairing in iPi Recorder again. If still unsuccessful, provide a trace log from iPi Recorder after closing the pairing wizard. You can access the trace window by clicking the button in the top-right corner of the main window. Before pairing, open the trace window and change log level to Verbose.
Also, please watch this pairing video just to be sure you're doing it right.
