http://forum.ipisoft.com/
Best height for 6-8 PS Eye cameras?
http://forum.ipisoft.com/viewtopic.php?f=7&t=10078
Author:  derek [ Tue Feb 12, 2019 5:46 pm ]
Post subject:  Best height for 6-8 PS Eye cameras?
Is there any info regarding the best heights the PS Eye cameras should be mounted when setting up mocap? The iPi Soft user guide has suggested heights for 3 camera setups, but nothing beyond that. We are setting up a studio space with 6 to 8 cameras. Thoughts?
Author:  vmaslov [ Wed Feb 13, 2019 3:04 am ]
Post subject:  Re: Best height for 6-8 PS Eye cameras?
The general rule of thumb for color cameras is placing one per each 4 at a greater height of 2 - 2.5m and others at 1 - 1.5m.
However, for specific motions other setups may be more beneficial. For instance, when an actor is lying on the floor or crawling, you can improve tracking quality by placing more (like half) cameras higher, up to the ceiling level.
Author:  derek [ Wed Feb 13, 2019 12:10 pm ]
So if I understand correctly, the cameras should generally be 1-1.5m, with every 4th camera at a greater height of 2-2.5m. We have 8 PS Eye cameras here - is there a benefit to mounting all 8, as opposed to 6, as far as capture quality? Any other tips would be great!
Thanks again.
Author:  Greenlaw [ Wed Feb 13, 2019 4:41 pm ]
The heights don't need to be so specific; the heights you use should depend on the motions you're capturing. In a nutshell, the camera heights are staggered to improve coverage, and some motions benefit from different coverage angles.
Also, staggering the camera heights makes it easier for iPi Mocap Studio to identify each one when calibrating the scene. So it's NOT a good idea to use the same heights for multiple cameras.
When positioning the cameras, go for the best visual coverage of the action you're trying to record. The example vmaslov gave is a good one: if the performer is lying down on the floor, then having the camera higher up allows them to see more of the the motion than if they were all at eye level or lower. If the performer is mainly standing, then favoring eye level positions is better. You still want to stagger the heights though and make the positions obviously different for scene calibration.
That said, this does not mean you should move the cameras for every capture. Try to plan your motions so similar performances can be recorded together. Then, when there is a drastic change, decide if you need to move the cameras and re-calibrate the scene.
Because of this, I don't recommend mounting the cameras in permanent room locations. It's more flexible to use tripods and other move-able camera mounts.
