It is currently Wed Jul 15, 2020 2:14 am
PostPosted: Sun Oct 03, 2010 5:45 pm
The system I intended to use for capture is XP 64 bit. I'm unable to setup CL-Eye-Driver and iPRecorder doesn't seem to recognize the cameras either.
Does any of the software work on XP 64 or do I need to use a different system?
PostPosted: Mon Oct 04, 2010 4:12 am
It works on XP x64, we have tested it.
www.apside3d.fr
PostPosted: Mon Oct 04, 2010 6:29 pm
OK. Whatever it is about my system it's inhibiting my ability to install the driver or get iPRecorder to see the cameras. Does anyone have any debugging advice?
PostPosted: Wed Oct 06, 2010 12:02 am
I don't remember exactly but the ipi installer should include the PSEye driver. Does it works when you launch the install ?
Maybe XP64 needs a special driver.
PostPosted: Wed Oct 06, 2010 8:07 am
That's correct.
It seemed to me that when the drivers became included with the release version of iPi Recorder Installer I needed to make sure all the old beta software, including the CL-Eye drivers, were completely removed before I could successfully install the new software. In theory, you should not have to use the separate CL-Eye driver installer to use PS3 Eye cameras with the current iPi Recorder.
FWIW, I know the current iPi Recorder installer works for Vista Ultimate and Windows 7 Professional, but I have not tested it with XP Professional.
