This may have been addressed before, but I thought perhaps I could contribute something useful. The Ps3 cams obviously have no tripod socket, but one can be added relatively easily. The thread on a standard tripod is 1/4-20 NC. You can purchase a tap of that size and a handle at any hardware store. You also need a drill and a vise to hold the camera base. Don't try this without a vise, as you need to hold the base securely. Start with about a 1/8" drill and then enlarge the hole to 13/64". A drop of oil doesn't hurt as you drill. Trim the bottom rubber pad away from the hole. Then you can use the tap with a bit of oil to carefully cut threads in the hole. When you are done you will have a solid tripod mount on you cams.
