It is currently Sat Jan 18, 2020 9:53 am
PostPosted: Mon Nov 25, 2013 1:00 pm
Hi would someone kindly tell me what is the best setting for 8 cameras PS Eyes placement, circle, semi-circle, square, or what?
PostPosted: Mon Nov 25, 2013 11:30 pm
Any configuration which gives 360 degrees coverage of the capture area. Circle allows you to get the maximum capture area in case the space available for setup is practically unlimited. However, if your (rectangular) room has side with length less than 10m, then you'd better place the cameras in a more rectangualr way to get the maximum area.
In any setup, it is recommended to have 2-3 of 8 cameras at increased height (2.5m).
PostPosted: Tue Nov 26, 2013 9:25 am
Thank you very much for your reply
A user manual and updated with data from the version 2.5.1.159?
Recently we have acquired, but all existing tutorials are not consistent with the version I mention them, I hope there is already one with this version, Regards
PostPosted: Thu Nov 28, 2013 12:49 am
You can find the most current documentation in our wiki.
Video tutorials and the manual bundled with the software are updated less frequently. Some of our users make their own tutorials which can be found on YouTube.
