It is currently Wed Jan 22, 2020 8:02 pm
 Post subject: Hi-Mgapixel Web Cameras
PostPosted: Fri Dec 13, 2013 11:07 pm
Hi friends
This is Heet from India
I want to know that can i use any web camera with hi mega pixel i mean 16mp or 20mp instead of ps3 eye?
or should i buy kinect?
PostPosted: Sat Dec 14, 2013 8:15 am
Hi, Heet
If you have at least 3 web cams of the same model, then you can use them. Most probably, they support low resolution video modes, so you can reduce data bandwidth and possibly get higher and more stable frame rate. For full body motion capture, greater FPS values are preferred over greater resolution.
If you mean that you plan to use just 1 camera, then this can be only a depth sensor like Kinect.
