http://forum.ipisoft.com/
Capturing from 3 different video sources?
http://forum.ipisoft.com/viewtopic.php?f=7&t=9695
Author:  rubening87 [ Fri Jan 06, 2017 10:28 pm ]
Post subject:  Capturing from 3 different video sources?
hello, i was having an idea to quickly rip out animations from the games by recording the same animation from the different camera angles, since its a game character and not a person, it will perform the same movement everytime, so recording from differnet camera angles will be very possible... achieveing the exact same movement from different angles.
i was wondering if its possible 2 sincronize the videos to start the animation exactly on the same frame and then start capture/tracking the biped.. for example i did this video as example.
https://www.youtube.com/watch?v=dtt8gDCM-X0
tell me if you can check the video.
Author:  Snapz [ Sat Jan 07, 2017 1:08 pm ]
Post subject:  Re: Capturing from 3 different video sources?
Not possible at this time, iPi Studio will only open recordings in the .iPiVideo format recorded with their recorder, nor would you have the proper multi-cam calibration file needed for proper tracking.
I am also sure iPiSoft doesn't want people ripping video footage of animations created by other developers anyway, so will probably never be an option, even if could be made possible.
Re-enact the motions yourself and record them properly for use with iPi would be my suggestion and even a lot less work involved just using a Kinect 360 or Xbox One sensor, or two.
