It is currently Fri Feb 15, 2019 11:08 pm
PostPosted: Fri May 05, 2017 5:43 pm
Hey all, wondering if anyone can shed some light on this.
If I have a single USB 3.0 controller in my laptop, is it better to use 6 cameras at a lower framerate or 4 cameras at optimal framerate? what would likely achieve better results?
PostPosted: Sat May 06, 2017 1:43 am
I think this depends on kinds of motion you're going to capture. More cameras provide more points of view and that usually means higher accuracy. Thus I'd go with 6 cameras in general. However, fast motions like fighting and acrobatics may benefit more from higher FPS than from more POVs.
PostPosted: Sat May 06, 2017 11:03 am
Thanks for the advice! yes my project does involve a lot of fighting and acrobatics coincidentally. I will test both setups and see what works best... will post results!
