It is currently Fri Jan 17, 2020 11:57 am
 Post subject: Kinect One adaptor Q
PostPosted: Wed Jun 21, 2017 10:09 pm
Just purchased a 2nd hand Kinect One (model 1520) with cable (no box or instructions etc).
I believe I need an adapter for connecting to my PC's USB port.
Q is: Would the "Kinect One S" be the correct adapter? (its the only one I can find listed online) or is something else required?
Thanks for any advise;)
 Post subject: Re: Kinect One adaptor Q
PostPosted: Fri Jun 23, 2017 7:32 am
You need this adapter.
PostPosted: Fri Jun 23, 2017 6:20 pm
Thanks;)
PostPosted: Mon Jul 03, 2017 10:37 pm
Aaaaaargh
I am in Australia, the adapter recommended is incompatable with Australian power supply.
Anyone know what planet this thing is from so I can now waste money on the correct power supply?
PostPosted: Mon Jul 03, 2017 11:09 pm
Okay looks like a type 'A' pin (USA), now all I need is an adapter for the adapter.
Good thing I opted to only go with a one camera setup.
PostPosted: Wed Jul 12, 2017 6:58 pm
Finally got the Kinect adapter & power adapter sorted
but
The Kinect SDK will not install, I followed the recommendation to switch of UAC but this made no difference.
Has anyone else run into this issue?
Windows 7 64bit
i7
8gig ram
UAC (off)
PostPosted: Thu Jul 13, 2017 1:51 am
Kinect 2 SDK will only run on 64-bit Windows 8+. Check this page in case you've missed some other requirements.
https://developer.microsoft.com/en-us/windows/kinect/hardware-setup
PostPosted: Thu Jul 13, 2017 5:25 pm
I'm using sdk1.8 which is supposed to work with Win7.
PostPosted: Fri Jul 14, 2017 12:56 am
Kinect SDK v1.x supports first-generation Kinects (Kinect for XBOX 360, Kinect v1 for Windows). Kinect for XBOX One is a second-generation device which requires Kinect SDK v2 for operation.
PostPosted: Mon Jul 17, 2017 6:16 am
Okay
1 Downloaded SDK 2.0 to my other (heavier & harder to move Win10 box) .
2 Installed SDK 2.0
3 Plugged in the Kinect (usb 3 & power) which results in 3 red lights & a white lighted logo on the right of the kinect.
4 The SDK instructions say that installation will complete after it is connected but I am getting no indication that this is happening.
Checked the Devices and Printers and the Kinect is listed as Unspecified.
Checked the Device Manager and he Kinect is listed.
Q: Is this what is expected in regards to installation?
(ie: Is there anything further in regards to installation?)
