It is currently Sat Sep 26, 2020 4:58 pm
PostPosted: Wed Nov 15, 2017 6:16 am
Hello everybody,
currently i am doing a project which requires using multiples cameras on a single raspberry pi board. I was wondering if it is possible to use multiple cameras on a single raspberry pi board ?
and if it's possible then how to use it.
I didn't find the right solution from the internet.
References:
https://www.raspberrypi.org/forums/view ... hp?t=50142
product launch
PostPosted: Wed Nov 22, 2017 6:56 am
Check here: Multiple cameras with the Raspberry Pi and OpenCV : https://www.pyimagesearch.com/2016/01/1 ... nd-opencv/
Probably will not work using iPi Recorder. if that is what you are attempting.
