It is currently Sun Jul 12, 2020 6:48 am
Post a new topicPost a reply Page 1 of 3   [ 24 posts ]
Go to page 1, 2, 3  Next
 Post subject: FOV
PostPosted: Tue Sep 01, 2009 7:21 pm
How can I find out my Camera's FOV angle. I have a few different kinds of cameras.
Also what would be a good tool for putting 3 videos together side by side like ipi recorder?
 Post subject: Re: FOV
PostPosted: Wed Sep 02, 2009 10:32 am
The calibration tool in the Downloads area is for figuring out the FOV of a camera.
BTW, if you happen to be using the Logitech Quickcam Pro 9000, the FOV is about 75. This is the only one I know about.
I think would be nice if there was a list of FOVs for different cameras posted somewhere.
PostPosted: Sat Sep 05, 2009 12:24 pm
You should check this discussion on recommendations how to do it:
viewtopic.php?f=3&t=24&p=103
PostPosted: Sat Sep 05, 2009 12:39 pm
Michael Nikonov wrote:
iPi Studio downscales video internally to 320x240 for processing. Input video can actually be any resolution. But it must have 4:3 aspect ratio (current limitation).
Michael - Is this still true?
PostPosted: Sat Sep 05, 2009 1:05 pm
No.
Latest version dynamically adjusts resolution. Typically, it processes at 320x240 during first tracking pass and at 640x480 or higher during second tracking pass.
PostPosted: Sat Sep 05, 2009 11:16 pm
So does the system prefer video that's 480 high now? Or does iPi interpolate the 240 version for the high res pass?
Does the capture software allow you to capture at higher res? Just wondering because I think I'm only getting 240 high video now. (Without looking, I'm guessing that I will have to set the res this in the Logitech control panel.) Even if iPi Studio can use higher res, however, I'm not sure my laptop will be able to capture four cameras simultaneously at 480.
I think will have to look into this for my next session.
PostPosted: Sun Sep 06, 2009 10:07 am
If you shoot video at relatively close space (under 5 meters from camera to actor) you should be OK with 320x240. The 640x480 resolution is useful for filming in large capture volume, when you need to film running, jumping, walking etc.
You can select resolutions and frame rates in iPi Recorder.
Modern dual-core laptops are not capable of filming a 3-camera video at 640x480.
You can film with 3 or more cameras at 640x480 if you have a fast CPU (quad-core or overclocked 4 GHz dual-core).
PostPosted: Sun Sep 06, 2009 11:36 am
Michael,
Thanks once again for the useful information! I was planning a shoot at work sometime in the next week or two, which has a much larger space for performance. I thought I would use my laptop to capture video, but with this new information, I will get permission to use one of our on-site workstations instead.
PostPosted: Mon Sep 07, 2009 8:30 am
I've just found out that Logitech webcams (and possibly other webcams, too) have image quality issues at 30 frames per second:
http://forums.quickcamteam.net/showthread.php?tid=548
Basically, people at Logitech forum are saying that Logitech QuickCam Pro at 640x480 @ 30 FPS looks like up-scaled 320x240.
So probably 640x480 do not have much advantage over 320x240.
PostPosted: Mon Sep 07, 2009 12:58 pm
Michael - are there any cameras that do provide the correct output?
BTW - in their current feature list:
http://www.quickcamteam.net/devices/
They still claim 1280 x 720 for 30 fps.
http://www.quickcamteam.net/devices/log ... t_list.pdf
