It is currently Mon Jan 18, 2021 12:56 pm
PostPosted: Fri Aug 02, 2013 8:50 am
Hi I have a question! for this program should I buy Xbox360 kinect or windows kinect? can I give a better result with windows kinect?
PostPosted: Sat Aug 03, 2013 8:27 am
Kinect for XBOX 360 is currently supported. Though it may be abandoned in future versions of Kinect SDK.
Kinect for Windows has better color image quality. However, this image is not currently used for tracking.
PostPosted: Sat Aug 03, 2013 12:57 pm
Thanks I have one more question. how much it would be better if we use 2 kinect instead of 1 kinect? I know there is videos for difference between one Kinect and two Kinect but I can't download them right now
Would two Kinect really give me more smoother animation than 1 Kinect?
Thanks.
PostPosted: Sat Aug 03, 2013 1:21 pm
Usage of 2 Kinects greatly reduces occlusion issues. This allows to capture more complex motions like 360 degrees turns and increases the accuracy when capturing simple motions.
If you only intend to capture the actor primarily facing in one direction, then single Kinect may be sufficient.
