It is currently Sat Jul 11, 2020 7:26 pm
Post a new topicPost a reply Page 2 of 2   [ 12 posts ]
Go to page Previous  1, 2
 Post subject: Re: 8 cameras running
PostPosted: Fri Aug 09, 2013 11:17 pm
I'm curious too. I know my gear is not going to be able to handle 8 cameras so I haven't bothered, but I may upgrade my main desktop computer next year if I can afford it.
PostPosted: Fri Aug 23, 2013 8:33 pm
I did try connecting the internal power connectors on my two usb 3 pci-e controllers and it appeared to make the system unstable. So I disconnected them and all's well. Glad they didn't burn! The controller user guide does not say to connect them, so why are they there? Bizarre.
I also upgraded from 850 watt power supply to 1100. Also added stability to system. Also I use an SSD which helps a lot. I didn't know I could create a ram disk on a PC (used to do it on a Mac back in the 90s!).
My question: did someone say you can connect more than two eye cameras (at 60 hz) to a usb 3 controller with just two connectors? By using a hub? Would that work? It's just that my motherboard user guide says that using one of the pci-e slots (the only one remaining) would share bandwidth with one of my (2) graphics cards. I would love to go from 6 cameras (with fairly good results) to 8 (with even better results?) but not sure whether to get a 3rd pci-e usb 3 controller or a couple of hubs for the 2 controllers I've already got (also using motherboard's usb 3 controller with, unfortunately, only two connectors).
Advice appreciated, thanks!
Users browsing this forum: No registered users and 5 guests
