It is currently Tue Jul 07, 2020 3:21 pm
PostPosted: Tue Feb 18, 2014 1:49 am
Hi!
I already have one Xbox Kinect on me but would like to purchase an Xtion - do these work together as 2 depth camera-setup?
Thanks guys!
PostPosted: Tue Feb 18, 2014 5:54 am
Yes, our software supports a configuration with the mix of depth sensors.
It is not recommended though, because you may encounter more problems than with a single model config. But that's your choice ;) Once up and running in iPi Recorder, they should work fine together.
PostPosted: Tue Feb 18, 2014 11:31 pm
Thanks a lot for the answer!
PostPosted: Thu Nov 06, 2014 11:17 am
I have xbox Kinect 360 + Kinect for windows v2. but ipi recorder is saying they are not compatible? I am in a big trouble... I was saving money for pro version but now I feel sucide lol...plz mercy help me...
PostPosted: Thu Nov 06, 2014 1:54 pm
The issue is the SDK for Kinect v2 no longer supports Kinect v1.
I'm curious if the old OpenNI drivers will work, unfortunately I can't seem to find the correct driver :\
PostPosted: Fri Nov 07, 2014 5:20 am
Kinect SDK v2 supports only Kinect 2 devices.
Kinect 1 (including XBOX 360 version) is supported with Kinect SDK v1 (1.8 latest) or older PrimeSense drivers for OpenNI.
iPi Recorder can use both Kinect SDK v1 (for Kinect 1) and Kinect SDK v2 (for Kinect 2). But the devices itself cannot be mixed in a single record currently because they have different hardware specs (sensor resolution, FOV etc). Recorder can only mix devices with similar specs - like Kinect 1 and ASUS Xtion, for example, which both are based on the same internals.
PostPosted: Fri Nov 07, 2014 11:04 am
oh that's sad news. Now I have Kinect v2 for windows and Xbox 360 Kinect. Please suggest and guide me. Which Kinect should I buy, Kinect v2 or Xbox 360. I already have both of them. but I want 2 kinects for better motion capturing...
PostPosted: Fri Nov 07, 2014 11:20 am
If you are limited on budget, I recommend you to get second Kinect for XBOX 360. You can use 2 or 3 Kinects for XBOX 360 with our software and a single PC.
PostPosted: Fri Nov 07, 2014 2:50 pm
yep I will buy one more Kinect xbox 360. Because I am saving money for ipi studio pro version. Thank you and good wishes for entire IPISOFT team.
