It is currently Mon Feb 24, 2020 10:39 pm
PostPosted: Mon May 25, 2015 2:59 pm
I was thinking about getting Ipisoft to use with the source filmmaker. I saw a tutorial on how to do so, but it seemed unnecessarily complicated, and also seemed like it was using an older version of ipisoft.
Is in the new version a feature to export directly as a .dmx? I understand that you can import source model files, and that comes with the rig. But can you take that rig from there and use it in SFM?
This will most likely decide whether I use the program, because I don't want to have to spend an hour converting from mocap to SFM.
Thanks.
PostPosted: Tue May 26, 2015 2:14 am
The DMX format is supported both for import and export. See our docs for details:
http://docs.ipisoft.com/Animation_Export#DMX
I encourage you to test the trial version of the software to determine whether it satisfies your needs.
PostPosted: Tue May 26, 2015 9:18 am
Okay. Thank you for replying. I'll try out the software trial.
