I believe higher recording frame rate would only apply really to higher Hz monitors, pertaining to iPi processing, most are still on 1080p 60 Hz refresh rate monitors, (soon to not be the norm shortly though), so they only refresh at 60 fps anyway and higher fps would only really adds to timeline length for iPi, so just adding to processing time, if it were a marker based system higher frame rate recording would help for the much smaller marker tracking.
Playback with a higher frame rate would give a smoother look, but not sure that would apply to iPi processing, or quality of the tracking for the most part.
Yes, I see your point, if someone had a large recording area to set up in to get the full focal length for the PS Eyes, or other cameras, but they would also need many more cameras, which also would add to the processing time for most high end machines even, but if had that much area and able to buy many higher res cameras, and processing machine to match, that could definitely be a plus to use them, or if recording in outside conditions, I could see that as viable.
Maybe some larger studios using iPi are already doing this method, but you don't hear much from them in this forum :)
iPi based their system for use in smaller areas which gives more appeal to the small studio and home user groups, as well as cost for the basic version anyway, and in my opinion have done pretty well with the output quality for just cheap PS Eye cams or Depth sensors.
Recent processed video using the new algorithm using 6 PS Eyes in a 10' x 12' capture volume in a 12' x 22' room: Any glitching usually from screen recording process.
https://youtu.be/VJ8X8PCIcEI ... Basic loop tested using iPi copy/paste pose 2x on end of timeline, then basic adjusting using Webanimate, but speed off a little.
https://youtu.be/O8Q0VHqiQr4 ... Better quality screen capture used now.
