It is currently Tue Feb 25, 2020 4:43 pm
Post a new topicPost a reply Page 1 of 4   [ 33 posts ]
Go to page 1, 2, 3, 4  Next
 Post subject: Kinect V2 Frame drops
PostPosted: Mon May 16, 2016 8:22 am
Hi !
In ipi Recorder statistics are red and framerate is below 30fps, while it works perfectly in Kinect Studio v2.
CPU: i5 2500k
GPU: Nvidia Geforce GTX 970
RAM: 16GB DDR3
any ideas ?
PostPosted: Mon May 16, 2016 9:25 am
Alright I just found a solution.
Keeping Kinect Studio 2 in the background improves framerate to 29.6 fps.
PostPosted: Sat Sep 10, 2016 11:33 pm
I tried this and my fps went down slightly. :-(
Just buy this it works.
PostPosted: Sat Feb 04, 2017 11:45 pm
I've got a similar problem - low framerate, on a very high spec laptop with the latest Kinect sensor. Anyone else got any ideas?
PostPosted: Sat Feb 11, 2017 4:28 pm
I have a similar problem. Have 3x Kinect 2 depth sensor configuration. 2 of the depth sensors are on lower spec hardware, yet they have no problems maintaining a close to 30fps frame rate. One of the 3 sensors is running on a new Alienware R4 i7 16GB RAM, PCI-SSD, GeForce 1060 laptop, and it sometimes struggles to achieve 25fps. Sometimes a clean reboot and having absolutely no other apps running helps, sometimes not. Not clear to me where the bottleneck is. Any suggestions welcome.
PostPosted: Fri Feb 17, 2017 5:20 am
Does it have a built-in Intel graphics in addition to GeForce 1060? Try disabling either one of GPUs completely.
PostPosted: Sun Feb 19, 2017 4:08 pm
I'm having the same issue with Kinect 2 on a 2016 MacBook Pro (running Win10 in Bootcamp). My iPi Recorder either records at a incredibly low framerate (under 5 FPS) or straight-up crashes at the first movement. The system specs are:
- 2.6GHz quad-core Intel Core i7
- 16GB RAM
- Radeon Pro 460 with 4GB RAM
- Windows 10 (Configured to focus on high performance...but there's always a chance I missed a setting.)
This is especially odd as I previously used iPi Recorder on a 2012 MacBook Pro running Windows 10 and experienced no performance issues. Here's a sample: https://www.youtube.com/watch?v=JY5oxu0wnvU
So, the only other thing that's changed besides the laptop specs is I'm using a USB to USB-C adaptor for the Kinect 2. However, I recorded video with Kinect Studio 2.0 and the framerate is a solid 30 FPS.
I'm at a complete loss for why my performance has taken such a significant turn for the worse compared to 4-year old hardware.
Any advice would be appreciated.
PostPosted: Mon Feb 20, 2017 1:12 am
I would say Kinect has hard times with the USB 3.1 controller in your new MacBook. However, if you claim it works like a charm in Kinect Studio, then I'm lost.
BTW how do you know the FPS in Kinect Studio? AFAIK it is not shown anywhere.
PostPosted: Mon Apr 03, 2017 7:48 pm
FPS counter shows up if it's below normal.
PostPosted: Fri Jun 16, 2017 2:19 am
Not to be overly dramatic but after many many[MANY] hours of throwing myself at the wall I might have finally found the solution.
After disabling Pagefile my framerate went from around 25 to solid 30.
Here is a tutorial: http://tunecomp.net/win10-page-file-disable/
Can I have a cookie now?
Users browsing this forum: Google [Bot], MSN [Bot] and 2 guests
